Old 24-02-2006, 11:50 PM   #1
starkersEB
starkersEB's Avatar
Default What does INTECH mean?
Like the title says what does it stand for?
starkersEB is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2006, 11:51 PM   #2
needfordspeed
inline technolgy? That's what i always thought it stood for.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2006, 12:03 AM   #3
b2tf
not here much anymore
b2tf's Avatar
its just a name given to the engine, doesnt really stand for anything.
2024 F150 XLT
Old 25-02-2006, 12:15 AM   #4
svo347
AFF's 1st DM.......
svo347's Avatar
I thought it was more "Jargon"
in.. tech
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 25-02-2006, 01:40 PM   #5
sphell
sphell's Avatar
who cares? But with a cool name like that, IT MUST BE GOOD :nutsycuck
Old 25-02-2006, 02:19 PM   #6
svo347
AFF's 1st DM.......
svo347's Avatar
strange how the US use it also with their triton motors etc.
13.21 @107.7mph
Old 25-02-2006, 04:33 PM   #7
ef_classic
ef_classic's Avatar
I read somewhere its called INTECH cos of all the new tech it had inside.
ef_classic is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2006, 11:54 PM   #8
T_Terror
The Guy You Love To Hate
INline Technology.
T_Terror is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2006, 12:56 AM   #9
svo347
AFF's 1st DM.......
svo347's Avatar
Originally Posted by T_Terror
INline Technology.
nope
Engine options:
* 5.4 L Intech DOHC V8, 300 hp (224 kW)
13.21 @107.7mph
Old 26-02-2006, 07:54 AM   #10
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Alien code designed to brainwash humans to buy fords. (Ford is also owned by aliens)
Just a few.
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2024, 04:16 PM   #11
asimplelife
mechanical novice hopeful
Default Re: What does INTECH mean?
I've had a look for this answer myself. The conclusion I came to, as sort of suggested above, is its a name coined in the US (for reasons unknown) for the modular engine V8's used in Lincolns. Which someone in Australia decided to re-use for AU Falcons. Again for no particular reason;"...The 4-valve DOHC version of the Modular engine was introduced in the 1993 Lincoln Mark VIII as the 4.6 L Four-Cam V8. Lincoln marketed the engine under the name InTech after 1995..."I couldn't find a mention of the name Intech in my book;"Ford Australia - The Cars and the People Who Built Them."This Wikipedia page comes the closest;"Ford Australia redesigned the I-6 again, naming it the Intech, in 1998 alongside the introduction of the Ford Falcon (AU)...".And some related info from a few other places;"...The "Intech" designation was only assigned to the 1998-2002 model years...""...The 4.0 Intech is a transitional engine...""...The new Intech engine retains the balance of an inline six and now wants to be revved above 3000rpm. The car delivers eight per cent better fuel economy and equals the economy of the 2.0-litre Escort of 1980...""...A revision on the SOHC engine first introduced with the EA in 1988, the Intech has many unique parts, including a longer rod, shorter piston, thinner valves, lower ratio rocker arms, MLS head gasket and cross-bolted oil sump.These changes did not lift the on-paper power output of the engine but did result in a higher revving engine..."(yes...I realise it's a bit of a thread mine...not to mention, not being particularly important )
asimplelife is offline   Reply With Quote Multi-Quote with this Post
