Old 27-02-2006, 08:20 AM   #1
Ian Sharpe
Default Advice re EL FairMont Wagon diff
Hi Guys,
My diff makes a bit of whining noise, so if I have to spend $$$ at the diff shop, I would want to:
Get new crownwheel & pinion fitted with 3.45 ratio. (3.23 at present)
Is it possible to get the cw&p new & at what cost?? or would I be better off getting a cheapie from the wreckers & have that recoed & lapped etc??
As far as the tranny goes , is it a simple matter of swapping a speedo cog to get the speedo correct for the different ratio?? Or does FORD use some other method??
cheers
Bog stock EL Fairmont Wagon
Ian Sharpe is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2006, 09:49 AM   #2
ilsautomotive
Former E-Series Member
G'day Ian,
Regarding the tranny, yes there is a small piece of cogged plastic which is inexpensive from Ford.
Most people who bother to have diff work done will get an LSD conversion at the same time. I would have thought an EL would have a 3.08 stock?
Normal prices including labour are in the $700-900 range for 3.45 gearing and an LSD centre using reco parts, whereas new can cost $1500.
Old 27-02-2006, 10:33 AM   #3
Ian Sharpe
Originally Posted by Trouty
G'day Ian,
Trouty,
thanks for your reply.
The diff is missing the ratio tag, so I am only going on what the owners manual says which specifies 3.23 for wagons.
I am not that fussed with lsd's having come from a 4wd background, i find that they are not much better than standard & they lose effectiveness after a while,anyway. I have front & rear lockers on my Pajero!.
So I guess I need to know if I can just buy the 3.45 cw&p & use my non lsd hemisphere & maybe just get the bearings done. The diff whines which from past experience is not a bearing fault. The cw&p should swap straight in , shouldnt it?? Were the cw& pinions for the sedans different from the wagons(apart from the ratio), as the wagons have a leaf rear end?? That would stuff me up asn there we no Ghia or Xr6 wagons!.
As for the speedo cog, I would just go to the dealer & get one for a EL Ghia , is that correct.
cheers
Old 27-02-2006, 10:34 AM   #4
niko
likes falcon's
niko's Avatar
xr6 would be same aswell
www.carhubsales.com.au
