Old 28-02-2006, 11:10 PM   #1
holdenhatr01
Fairmont Fanger
Default rev problems with big cam?
Hey guys i have a 97 fairmont and had the engine worked and added a stage 3 crow cam. Arfter getting it back it has idled at about 1 to 1.5 grand constantly. Has anyone had a similar problem and worked out how to fix it. Thanx
holdenhatr01 is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2006, 11:56 AM   #2
OED666
OED666's Avatar
do you have a chip at all???
mine idled rather high after getting it tuned... i was told the power steering pressure switch was faulty. i replaced that, and it was a little better... my idle speed control motor was also playing up, and it sorted it out...
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2006, 12:30 PM   #3
Southy
you need your computer recalibrated or a chip. it says so on the crow site
Southy is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2006, 07:31 PM   #4
Rollin
Rollin's Avatar
check for air leaks...if anything, a worked e-series with a stock computer should stall and idle low, not the other way around...
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2006, 07:46 PM   #5
Southy
yeah ill second that. check you MAP sensor lines (do els have map sensors lol?) and also check the condition of the vacume gauge that leads into the rocker cover. there is another hose that goes into the back of the rocker cover (check that too)
Old 01-03-2006, 09:57 PM   #6
hornet
hornet's Avatar
yes they have MAP sensors.
thats what you get for buying a cam that doesn't run on a standard chip ;)
Plenty of cams out there that run on standard ECU's, Alted, JMM for example.
5 Speed EL Futura
140rwkw last dyno
hornet is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2006, 10:04 PM   #7
Southy
my Stage 3 Crow runs on my stock ECU perfect!
Old 01-03-2006, 10:37 PM   #8
Vic
5.6L of carbon footprint
Vic's Avatar
I6 ECU's don't tolerate mild+ cam's very well as there's just not enough MAP value parameters for the stock ECU to use. A way around this might be to upgrade to an XR6 ECU unless of course you're running a Fairmont Ghia with speed sensitive power steering because that is built into the stock Ghia ECU.
Running Wolf v500 ECU ~ standalone.
Controls the engine, the dashboard & it's instruments and also fully controlling the BTR97 including soft / hard shifting, shift points, kickdown, line pressure etc
Vic is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2006, 12:34 AM   #9
Walkinshaw
Two > One
Walkinshaw's Avatar
Chip or aftermarket ecu, no other choice.
Old 12-03-2006, 01:05 AM   #10
heckaz performance
You can fit a chip but mine did bugger all to help and they fu%$ed around for ages trying to fix it too. (damn chiptorque the chips a dunger). They don't really have a clue and its a shame we have to deal with clowns that will actually let a car leave like that. They have no pride in their work, my A/C has never worked since and the car seemed to have lost power with the HP4 chip. I wouldn't let them take your money. Flasher systems will soon be available for the E-series, which will be far superior to any chip for only a little more money. The main thing that buggers the idle is the ICV amplifying the lope of the cam. It can also seem like a sticky throttle. I fitted an aluminium plate under the ICV with smaller holes than usual and it now works fine.
heckaz performance is offline   Reply With Quote Multi-Quote with this Post
