Old 02-03-2006, 08:55 PM   #1
MrFlibbles
ill have a beer milkshake
MrFlibbles's Avatar
Default Big brakes for my ef?
Has anyone put big brakes onto thier ef? if so what did you use? i want to fill up behind my wheels and also stop a bit better! (mine also has abs)
sorry if this has been a repost but i searched and came up with nothing - then again i am computeretarded.....
current cars:
2001 AU SII XR6 manual
2001 Nissan Patrol
1969 Isuzu Florian
1976 Chev luv (really its just a rebadged Isuzu!)
1980 Isuzu KB 4x4
MrFlibbles is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2006, 09:11 PM   #2
vegabass
BASS ON BOARD!
vegabass's Avatar
Im working on putting twin pistons from the AUII/BA on the EL....seeing if its a cost effective way of doing things rather than buying a aftermarket kit such as PBR.
you could find EL GT brakes they did a decent job
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2006, 09:32 PM   #3
fairmont1998
fairmont1998's Avatar
On Fordmods there are a few threads about EL GT and similar brakes. The conversions aren't too dear either.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2006, 12:50 PM   #4
parawolf
beep beep
You can get ADR complaince kits of 4 piston AP Racing big brakes from Cebco here in Melbourne. I'm sure they do postage, but the weight of the calipers and discs could make it cheaper to come for a drive...
Nothing to see here, move along, move along...
parawolf is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2006, 01:51 PM   #5
oneredED
need more boost
oneredED's Avatar
I was at Hitech brakes or whatever they're called the other day looking into this, and they do a twin-pot conversion for e-series from AUII's, which open up more of the DBA rotor range (4000 & 5000 series) to us. The price is around $2k I think.
'94 ED Falcon GLi
Suspended by: kings, koni, pedders
Rolls on: 17" AJR Director's
Stops due to: bendix, DBA
Shifter connected to: T5 manual
Power from: ???
Interior: velour and woodgrain
Cost: stuff all :P
oneredED is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2006, 09:27 PM   #6
urippa45
i put cross drilled and slotted on mine with hard pads and it stops really quick no abs and doesnt lock up. The EF rear brakes are bigger than normal, i think cross drilled n slotted is the best way to go.
urippa45 is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2006, 09:39 PM   #7
347Stroker
347Stroker's Avatar
ELGT/FBT brakes are terrible really....very overrated.
Thats why I have this on my EL XR and have left the GT/FBT in the shed.
347Stroker is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2006, 09:41 PM   #8
LUXO_8
windsor user
interesting, looks very neat
a few of us eseries guys are looking into AU front and rear suspension conversions..... this enables us to use any AU brakes you'd want...i'd love some brembo's and T3 azzuro rims on my car ....eventually
Old 03-03-2006, 10:06 PM   #9
svo347
AFF's 1st DM.......
svo347's Avatar
Sign me up scotty...
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 03-03-2006, 10:16 PM   #10
347Stroker
347Stroker's Avatar
Its alot easier than you would believe.....just have to convince the engineers.....
Old 04-03-2006, 07:54 PM   #11
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
It is true, but they are heaps better than stock.
Mine are the same calipers but i run the Cebco setup, with the hub in the disc.
What is the disc you are running?
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2006, 07:56 PM   #12
LUXO_8
windsor user
yep, we're just waiting for the guinnea pigs to complete their projects, then a few cars will be done........mine being one of them
i dont think it would be all that hard to have the engineer sign it off..... the chassis' are basically the same....
Old 04-03-2006, 09:41 PM   #13
parawolf
beep beep
You would hope your ABS wouldn't kick in if it didn't lock up. Cross drilled brakes are useless on a car the size of a falcon. The benefits of cross drilled brakes are that they offer reduced unsprung weight on the suspension. With the weight of a falcon in makes bugger all difference.
The disadvantages of crossed drilled on a street car and on a car the weight of a falcon are numerous. Reduced physical mass of the cross drilled means that they are unable to take the heat of repeated braking. Reduced physical strength of the cross drilled discs means that you have to far more regularly check the condition of the discs for fractures. If you don't bed the discs and pads in correctly it is likely you will have premature disc failure. In the case of pad replacement, you should resurface the disc to ensure accurate mating surface for effective braking - doing this with cross drilled brakes is more expensive than regular discs. As a final point, the reduced surface area means less effective braking for high speed, repetitive stops - eg track racing.
Now this is usually more common with your regular discs eg the DBA's. It doesn't apply so much with the more expensive discs that are found on the FPV's with the Brembos, on AMG's and Porsche's. On these platforms the discs are expensive - probably close on 10 times more expensive than the DBA product.
For best braking performance on a Falcon on a budget go with grooved + vented discs, as big as can possibly fit in your wheels and calipers. Only get cross drilled if you want them for looks.
