11-03-2006, 08:52 AM | #1 | ||
thinking of trying to take out the left headlight and air filter box and making up a mount so that the tubing goes straight from the throttlebody to the headlight and then running mesh inside of the headlight to stop bugs n ИИИИ gettin in. this would only be for when i take it to the drags.
think it would help? cheers |
11-03-2006, 08:55 AM | #2 | ||
[ 5L ]
just have it so that your have a pod in the engine bay behind where the headlight goes and take the head light out, less stuffing around with all the mesh and stuff then
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
11-03-2006, 08:59 AM | #3 | ||
id be sucking more cold air without the pod tho
11-03-2006, 10:26 AM | #4 | ||
MADED.6
it would wreck ur engine just run pod it would do a lil bit more without an enigne but ive seen a 2 stroke that had no air filter and dirt got in the chamber and the chamber and the piston were rooted so i wouldnt be doing it.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
11-03-2006, 12:57 PM | #5 | ||
I did that at heathcote worked better, Had better throttle response and more power, I put the mesh there so I wouldnt suck in a Bird...
11-03-2006, 02:15 PM | #6 | ||
slow & low EA Ghia
get your self an old head light and get a 3inch hole cut into the glass/plastic and then do the same for the back of the light and mount your pod right up against it, saw a ba xr do this once and it looked awsome if done right. thats the way i would be doing it. you would still want some sort of air filter just incase something slipped through, unless you were going to be using a very fine mesh? (like screen door mesh).
Ehab
Ea Fairmont Ghia 1988 |
11-03-2006, 02:27 PM | #7 | ||
you mean something like this. http://www.pearly351.com/eventpics/h...athcote70.html It seemed to work for me, even with my 3yo el cheapo filter. lol
