Old 24-03-2006, 09:51 PM   #1
TwistedEL
TwistedEL's Avatar
Default Measuring Sensor Voltages
How do you do this? Can you check them at the diagnostic connector in the fuse panel or do you have to supply the specified voltage to the sensor and read the return?
Old 24-03-2006, 10:16 PM   #2
sphell
sphell's Avatar
Just use a multimeter at the sensor. A lot of the sensors work off resistance though, so for ones like the temp sens, you'll have to switch it to ohms.
Old 24-03-2006, 10:25 PM   #3
TwistedEL
TwistedEL's Avatar
Yes I understand this but I'm saying if it needs the voltage how do you technically measure the values? Do you have to strip wires etc?
Old 24-03-2006, 10:30 PM   #4
sphell
sphell's Avatar
yeah u have to supply the voltage to the sensor....IE test with the car running or ign on. If you have a voltage type sensor then it won't read anything unless there is voltage supplied to it (with the exception of the oxygen sensor which creates it's own voltage).
