Old 26-03-2006, 01:13 AM   #1
wassa
Default au11 dedicated gas ute
just got this ute yesterday filled it up tonight the fuel gauge shows full but the dte shows 303 will this change or is it a fault? any idears would be great
wassa is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2006, 09:04 AM   #2
GK
Walking with God
GK's Avatar
It's a gas thing, the DTE on mine (dual fuel) takes a while to work up to the full distance. An electrical gremlin of sorts.
Others will tell you the exact reason, don't worry about it, go by the guage. You should get 14 litres per 100 or so.
GK
Old 26-03-2006, 11:37 AM   #3
smally289
growing up is optional
smally289's Avatar
The DTE number will fluctuate depending on how you drive too. After 3 hours of light throttle highway driving at 110kph and then refilling, my AUII wagon showed over 700km DTE. It only took 15 mins of city driving to make it fall to about 550km.
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2006, 07:24 PM   #4
Baboon_AU
Baboon_AU's Avatar
ford haven't figured out how to perfect this on factory gas cars.. my ute never shows the correct gauge or DTE readings.... it is because of the units on the side of the tanks.. if you would like a more accurate reading, look on the side of your tanks.. the right one can be seen through the right wheel arc and the left one can be seen throught the filler flap. talk to mechan1k about this problem as he has bought new units for his tanks and it has fixed the problem
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2006, 07:35 PM   #5
Smoked
Burnin Rubber
Smoked's Avatar
can you check the levels on the sedan?
Btw, my gauges appear fairly accurate.
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
