Old 10-04-2006, 11:55 AM   #1
djmaker
Default gas tank
hi i just called these people called a1 gas in hallam and i got quoted $350-$400 for a service of my gas tank... is this a reasonable price???? they said because my gas tank is over 10years old once they do the test its ok for a nother 10years.
Thanx
djmaker is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2006, 12:01 PM   #2
Gunns
Gunns's Avatar
$350 is ok, cos it cost $150 for them to send it away to get tested, so $200 for them to pull it out and reinstall it ain't to bad.
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2006, 12:02 PM   #3
trick_xd
I build your wish list...
trick_xd's Avatar
are you meaning you need a test to get your tank back into date ??
if you are then that is far to much
look for a DIVE SHOP or even the C.F.A.
The c.f.a. do it here for $97.50 as a straight test good for 10 years other bits are extra .
I had them do mine at x'mass time and they replaced the flote level and all up it was $118.20 and then you get it put back in by a auto gas center.. dont do it your self .
If it weren’t for physics and the law enforcement, I’d be unstoppable.
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2006, 12:09 PM   #4
djmaker
would it be a bit risky if you take out the tank your self??? cause $200 just to take it out and back in is pretty expensive.
Old 10-04-2006, 01:30 PM   #5
Walkinshaw
Two > One
Walkinshaw's Avatar
Im not sure where the legislation dictates that an authorised installer's work ends/starts. I'm reasonably sure anything to do with hard lines needs to be done by a professional. You may beable to install the tank yourself and get the gasplace to just fit the lines to the tank. Find out first though.
Old 10-04-2006, 01:42 PM   #6
djmaker
hmmm screw it ill just pay the dosh and get it done properly it only gotta be done once so might as well get it done properly...
but btw any one else got there gas tank serviced and for how much...
Thanx
Old 10-04-2006, 07:32 PM   #7
INJECTED_250
Custom user title
INJECTED_250's Avatar
Depends on the type of tank that is being tested. Some tanks can cost 200+ to get tested because the cheaper thanks (sprint gass, midleton) have all the valves/guages/AFL in one unit. THe APA tanks are cheap to test as they have seperate valves, guage floats, afl's. And not all need to be replaced
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 03:09 PM   #8
djmaker
well i got quoted by a place in dandy called all-tek automotives for $300 and i do have a apa tank so thats why its $300 this place is $50 cheaper then the other guys and also they said we highly doubt your converter needs changing cause if you can run gas then its working he said its probly either just running rich or it has a leak... he said $110 for a service and we will fix any leaks if we find any while we service it btw can i do anything to make it run less rich?? hence if thats the problem saving me a $110 service
GOOD PRICING????
thanx
Old 11-04-2006, 05:57 PM   #9
djmaker
hmmm came home from work and thought ill see if i can tell where the leak is coming from so i open the bonet turn the gas on and when it hit ignition i heard a SHPPPPPP sound and smelt gas bad... so i looked and one of the bolts on the left of the converter was spraying gas... called the guys im gonna take to get my gas tank done they said $20 ill see if i can just get it done for free with my $300 ....
Old 11-04-2006, 10:23 PM   #10
VertexZ
Ausgas charged me $220 for a retest and stamp.
VertexZ is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 09:19 AM   #11
djmaker
is ausgas in vic???? cant seem to find them in the yellowpages.. if they are in vic whats there number and where abouts are they thanx..
