Old 11-04-2006, 01:54 PM   #1
VS MANUAL
Default Diffs
Hi guys, great forum (even though im from th edark side)
Can anyone tell me if the early EA'S diff 2.92 or 2.73 i think will fit in a commodore diff? Or even just a centre swap will work?
Thanks in advance
VX SS - 6 SPEED - MAF TUNE - TWIN 2.5 INCH EXHAUST
VS MANUAL is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 02:03 PM   #2
niko
likes falcon's
niko's Avatar
there borg warner diffs arnt they? ring diff joint
www.carhubsales.com.au
Old 11-04-2006, 02:22 PM   #3
OED666
OED666's Avatar
ummm... good questino... yes they are BW diffs, but you will have to look out for 25 spline centres... you will want a 28 spline centre from an eb or ed...
for a definite answer, give mal wood automotive a call... talk to ben and he will be able to advise you...
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 04:13 PM   #4
heckaz performance
Diff gears can be swapped, for whatever ratio, although over 4.11's machining may be required to the housing. Provided centers are the same splinage should go in. Both Borgwarners.
heckaz performance is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 04:21 PM   #5
VS MANUAL
Thanks mate, ill give them a call.
Also noticed yor Qtr times and power, not bad for a NA 6!
Old 11-04-2006, 05:15 PM   #6
OED666
OED666's Avatar
yea, i plan on a recruiting a few more horses, and quicker times... low 14's and i will be happy... it was a very warm night that it did a 14.56...
Turbo Barra ED 4L
Old 11-04-2006, 05:19 PM   #7
RavenLS1
Originally Posted by VS MANUAL
not bad for a NA 6!
no mate,its just ford power.
405rwhp LS1, FG XR6T Ute manual, VE series 2 Omega LPG.
RavenLS1 is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 07:00 PM   #8
INJECTED_250
Custom user title
INJECTED_250's Avatar
every thing but the 2. 77 should be ok
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 07:21 PM   #9
Rollin
Rollin's Avatar
yeah all the diff gears except the 2.77 should be interchangable, but you will need to get them lapped in properley.
even if you swap the whole center you will need to get it lapped by a pro - failing to do that will mean you have a noisy diff that is weak and will wear out or break in no time.
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 10:15 PM   #10
fmc351
let it burn
Dont lap it in, just slap it in, itll feel just like a factory holden!
Old 12-04-2006, 09:09 AM   #11
VS MANUAL
Yeah, mine is pretty stuffed, but i wouldn't put it down to a holden, Borg Warner probably.
Also thanks Rollin, thats what i was told, just wanted to make sure first.
Old 12-04-2006, 09:21 AM   #12
TUFED6
TUFED6's Avatar
I've never seen one, whats different about the 2.77 ?
- John
TUFED6 is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 09:45 AM   #13
Walkinshaw
Two > One
Walkinshaw's Avatar
- John
2.77 runs a diffrent offset hemisphere.
Old 12-04-2006, 09:49 AM   #14
Gunns
Gunns's Avatar
- John
Uses a diffrent housing and centre.
Gunns is offline   Reply With Quote Multi-Quote with this Post
