Old 11-04-2006, 10:20 PM   #1
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
Default Power Stearing
ok i have a big problem when i do big rpm say over 4000 my power stering belts twist and endup comming off and then there stuffed, it sucks coz i have to keep the revs down witch is good coz i save alot of fule but it is abit embarising when you have a play in my car, i have been throught 7 belts this month i keep 3 spare in the boot im getting quite good at changing them but its costing about the same in petrol, what could be doing this. i need help
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2006, 11:08 PM   #2
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
So no one can help
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 12-04-2006, 10:59 AM   #3
mcflux
mcflux's Avatar
Well, when you post late at night and then repost within an hour, the odds *are* stacked against you for a prompt response.
I'll take a stab & say the pulleys aren't aligned... or one is unbalanced, so that at high rpm when the belt is turning faster, it is more unstable than at lower (sub-4000) rpms, and hence is thrown off.
I recall a recent thread about checking pulleys for balance by using a stethescope (or similar) device, where you can "hear" the unbalance/vibration occurring.
I don't suggest playing Doctor with a stethescope on the block though, you might nuke your eardrums :SaiyanSmi
Good luck
-Dave-
Old 12-04-2006, 01:09 PM   #4
AshMan
Girrrrr!!!
AshMan's Avatar
Doesn't this occur when there is play backwards and forwards in the crank?
Falcon EF XR6 in Heritage Green
Heritage green, isn't that a fence paint?
AshMan is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 03:21 PM   #5
fmc351
let it burn
Could be the pump mounting not as tight or complete as it should be either.
Look at pulleys and mounts for the defective units. May even be another belt, they usually throw all of them.
Old 12-04-2006, 05:31 PM   #6
Damo
i would say it's one of the pulleys for sure.
Old 12-04-2006, 05:38 PM   #7
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
it cant be the one on the motor as there are still 3 belts on that one and i dont think it could be the power stering pump can it so i guell im up for a new power stering pully
VE SS Ute manual 09
125 Thumpster 2010
Swag
