Old 11-04-2006, 11:28 PM   #1
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
Default timing on e-series... w/ bigger cam
hey all....
whats the way to go with spark timing on our cars..
what is everyones experiences on timing on aftermarket cams especially?
i was running at 21deg BTDC, and advanced further... runs fine no ping...
anywayz.. any comments?
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 07:40 AM   #2
Simmo
White Lightning
Simmo's Avatar
i think mine may be up around 26 degrees and i've never had problems. stock xr6 cam though and i always run ultimate. i reckon it would ping its guts off on 91RON.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 08:55 AM   #3
Walkinshaw
Two > One
Walkinshaw's Avatar
How are you checking the deg of advance? Have you marked your own TDC on the balancer? Its very common for the cars to slip the balancer and give you an incorect reading. This said. When i had EEC incontrol of the engine i had 20deg BTDC dialed in as static timing.
Old 12-04-2006, 09:56 PM   #4
santoitaliano
BF F6, APV SR3900
well was 21deg BTDC when it was put on the dyno.. since then ive advanced it more after i put new cam in...
Santo
Daily:
Bluepower enhanced.
Old 12-04-2006, 10:09 PM   #5
vegabass
BASS ON BOARD!
vegabass's Avatar
I have high compression aftermarket cam and my mechanic at one stage had 44deg advance.
We then backed it off to 39deg advance and I run ultimate.
Chiptorque were pussys with the timing in the chip so we did it the old fashioned way :Reverend: :thebirds: : :monkes:
TWIST!
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 10:21 PM   #6
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
I like pussys
I am at 32deg advance
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 10:23 PM   #7
vegabass
BASS ON BOARD!
vegabass's Avatar
Originally Posted by Clarke AV
I like pussys
We have something in common! :
meeeeooooowwww
