Old 22-04-2006, 08:52 PM   #1
jet111
jet111's Avatar
Default Bad vibrations on freeway...help!
I bought a EF XR6 last night and when you take your foot off the throttle the cabin starts to vibrate. No vibrations come through the steering wheel but the whole car shakes quite badly especially at high speeds.
Is this a common problem or anyone ever experienced this?
Thanks Mark
jet111 is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2006, 09:10 PM   #2
NZ
NZ's Avatar
First thing I'd check is the tailshaft flange bolts onto the diff. Then check the tailshaft uni joints.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
Old 22-04-2006, 10:10 PM   #3
jet111
jet111's Avatar
sweet as i will look into it
Old 22-04-2006, 10:36 PM   #4
falcon91
falcon91's Avatar
When you test drove it, which I'm sure you did?? What did the previous owner say it was??
falcon91 is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2006, 11:14 PM   #5
jet111
jet111's Avatar
i didnt test drive it at high speeds and had a mechanical inspection but they didnt pick up anything
Old 22-04-2006, 11:27 PM   #6
Eu-GenixX
Eu-GenixX's Avatar
my guess is something to do with driveline...
but does it make a flapping type noise when turning a particular direction... at medium sorta speed.. (60 km/h)
i had a problem at speed of the whole car shaking... (in a mirage tho).. and turned out to be massive eggs in the tyre surface.. not the wall.. but in the tread... replaced the wheels.. problem gone...
but your symptoms sound slightly different...
Eu-GenixX is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2006, 12:07 AM   #7
fmc351
let it burn
Maybe the ally tailshaft has been pulled out, and steel used. ???Tailshaft whip???
Old 23-04-2006, 08:46 AM   #8
Tiga_EL
Tiga_EL's Avatar
The tail shaft is prolly rubbing on something, my car does that at 80-85 km/h. If you accelerate you cant feel it once you let go of the accelerator it starts vibrating. Thats my guess as to what your problem could be.
Tiga_EL is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2006, 09:25 AM   #9
RG
Back to Le Frenchy
RG's Avatar
What sort of speed are we talking here?
Old 23-04-2006, 09:31 AM   #10
Dodge
i like to be stroked
Dodge's Avatar
could be rims, wheel bearings, bent drive shaft, axle, could be a option for lesbians too
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying "Damn...that was fun!"
Dodge is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2006, 09:36 AM   #11
RG
Back to Le Frenchy
RG's Avatar
Broken engine mount or gearbox mount maybe? I had a bent tailshaft in mine once and it vibrated like hell all the time so if it only happens off the power I would doubt that it's that.
Old 23-04-2006, 10:14 AM   #12
jet111
jet111's Avatar
It does it at 110km but not badly and only when off the power We were curious to see whether the problem went away so we took it up to 140 and the whole cabin started shaking even whilst accelerating.
Old 23-04-2006, 10:20 AM   #13
RG
Back to Le Frenchy
RG's Avatar
Sounds like it could be the tailshaft then. Best bet is to take it to a driveline/diff joint and get them to sort it out.
Old 23-04-2006, 10:21 AM   #14
RG
Back to Le Frenchy
RG's Avatar
Also is it manual or auto?
Old 23-04-2006, 10:29 AM   #15
Fairlane
V8 Powaah
Fairlane's Avatar
Put it in neutral at 110 and see what it does, might be an idea, it will be able to narrow it down a bit anyway (do this on a private road)
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2006, 05:19 PM   #16
jet111
jet111's Avatar
It's a manual
Old 23-04-2006, 05:23 PM   #17
RG
Back to Le Frenchy
RG's Avatar
It's a manual
I also had a problem with a bent mainshaft in the box when I got my first T5 that was out of a wreck. Your car ever been in a prang?
Old 23-04-2006, 05:32 PM   #18
jet111
jet111's Avatar
Not until we hit a roo on the way home!!! But the car was vibrating before this happened and there is no damage apart from a destroyed front bar and scratched radiator. The car still drives 100% no loss of power and Temp is completely normal.
Old 23-04-2006, 05:33 PM   #19
RG
Back to Le Frenchy
RG's Avatar
I'd be tipping a bent tailshaft or bent rear axle.
Old 23-04-2006, 11:39 PM   #20
mcflux
mcflux's Avatar
I'd say it's a uni joint. My 335,000km-old ones were buggered and would vibrate at around 130kph (with the 4.11s, meaning the tailshaft gets much more of a workout), and when I had the unis replaced both front & back that fixed the problem.
You could probably do the unis yourself if you're good with a spanner (I'm not!)
-Dave-
