01-05-2006, 04:46 PM | #1 | ||
All Bran = Regular Member
Don't assume that cars are assembled the same as 30 years ago.
Tip: before spending the best part of an hour searching for the right open-ended spanner, check if the lower shock absorber mount has a captive nut... (I hope I won't have to share tip number 3 which will concern correct use of a coil spring compressor and holes in the workshop roof...) |
01-05-2006, 05:18 PM | #2 | |||
Drought Breaker
Helps when someone lends you the right bloody spring compressors too!
2002 AUIII XL W/- Custom Tray
ALL COUNTRY: SW Platt Mccann 5 Poster, GME 4706 7' Whippys, Uniden UH015SX UHF AND Scanner combo, Narva Taurus Bull lights, Hawk Grille, Series II Pursuit Side Skirts, Stickers on the back window and more eartags than a mob of cranky angus ALL GO: XR6 VCT donk and ECU NO MORE!! Now even MORE fun with 200kw XR8 and 5 speed, Tickford Cluster, 3.45 LSD, full custom twin system w/- 3" chrome angle cut tips : |
01-05-2006, 05:50 PM | #3 | ||
buickman
Sounds as if you got in more trouble than a pregnant nun fitting the springs. It took me nearly 3 hours to do the lot on the AU Ghia I had . I used a air tool but it was not a leaker. I would be angry as hell if oil sprayed everywere inside the car.
01-05-2006, 07:51 PM | #4 | ||
Fantastic Plastic
mate , you need to take a bit more time and think about what you are doing before you just rush into things by the sounds of it, your gonna end up killing yourself at this rate ! (jokin ;) ..lol ) , if your not sure on something before attempting a repair or whatever - ask away on these forums - plenty of people here to put you on the right track ;) . cheers
01-05-2006, 08:13 PM | #5 | ||
thanks for the advice...I've taken it onboard, but I think I've just about got a handle on it ;)
