17-05-2006, 08:53 PM | #1 | ||
Hello, I posted this intro in "The Pub" section but since finding the E Series section I thought I would put a link to it here as well.
http://www.fordforums.com.au/showthread.php?t=49151 In regards to my cars drinking problem and occassional idle issue: In the short term I will give the CFI throttle body a good clean with carbie cleaner and replace the injector o rings... Can anyone advise on these? I noticed there where a few part numbers on the E series parts database for injector o rings. Do Ford parts places still stock them? Being a rubber product that perishes with age it is not good to buy a "new" item that is as old as the car. In the long term I will give pick and pull a visit to find a decent MPI donor car. The usual... manifold, throttle body, air box, intake pipng, wiring loom, ecu, fuel pump, fuel filter & bracket, fuel pump, distributor. Is that all that is needed to do the complete job? Also I did a search for "How To" check ecu fault codes but had no joy. Can anyone point me in the right direction? Thanks a lot, Cheers, Damian |
17-05-2006, 11:29 PM | #2 | ||
I think you have the MPI conversione sused out there, you will also need the A/C compressor brackets from an MPI car as it needs to be lowered.
Welcome to the forums. great name by the way. :hihi: |
18-05-2006, 12:36 AM | #3 | ||
TWiZTiD EA
you also need to grab a kick down cable if 3 speed and throttle cable aswell
10/89 EA 11 Spac5 Speed, Mpfi, EL XR6 Cam, EF/EL Thermo Fans, EL BBM Intake, Sports Exhurst, ED Bonnet, ED XR6 Boot, Boot Lip, Garnish and Lights, ED Electric Mirrors, Trip Computer, Clear Indicators, EB XR6 Steering Wheel, King Superlows, Monroe GT Shocks and EL GT copy Rims. 15.3 @ 90 mph |
