Hi all,
not sure if this should be here but here goes anyway. I just watched on mythbusters an episode about driving with the tailgate up causes more drag than with it down. They both drive some sort of pickups which were identical with the same amount of fuel etc.. The results were suprising to say the least, the pick up with the tailgate down ran out of fuel before the tailgate up pickup did which ran a further 30 miles before running out. Then they use some form of wind tunnel (water actually), and found that the pickup model with the tailgate down caused more drag then the pickup with it up. The pickup with the tailgate up caused a bubble of water in the bed and this in turn caused the faster moving water to glide over the bubble and pickup, where the tailgate down bursted this bubble causing the water to push down on the tailgate and cause more drag. So basicly, what do you ute drag racer think? i know a lot of you put it down, have you guys tested this? I just this was an interesting show and would like to see your thoughts on it ![]() Cheers Jim
BAXR8 A4.......CAI....CATBACK......10,000k's and real tyres at 29psi = 14.057 with a virgin driver :the_finge |
Virtuous Bogan (TM)
![]() Join Date: Jan 2005
phew glad I did a search.
I just caught the end of it.very interesting indeed as most drag people seem to think that it makes a difference having it down...anyone have any TIMED runs up and down? The only thing stopping their theory with drag racing is the speeds. I dont think they measured how fast the flow was in the tank? There might be a critical speed where it actually makes a difference in a drag race. ie - for the first half its not going that quick, but towards the end it might make a differnce.
Thats exactly what i thought would hapen if the tail gatewas left in, i gess what drag racers would do it for woul be to save some weight, not really aerodynamics.
Very interesting stuff though. |
#4 | |||
trying to get a leg over
![]() Join Date: Dec 2004
Taking it off is the best option, both for weight saving and aerodynamics
Cameron ------------------------------------------------------ |
Virtuous Bogan (TM)
Cam, I dont know if I am reading your post wrong but they say flow is better when its up, with the vortex.
Solution Was Boost 4?, 6 & 8
I always raced with mine down, Hamo now does the same... interesting discussion.
What type of Utes were they?
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
#7 | |||
But .05 seconds could also be any variable, maybe my imagination too.lol
turboute
It also will move 50?kg of weight 20-30cm's back wich could give a bit more weight leverage for traction over the back wheels (maybe could help)
Judging by the amount of depression in my tonneu cover when I travel at 100km/hr I would guess that over 100km/hr it would be good keeping it down - I can actually feel the downforce this generates on the end of my ute - probably the evivalent to over 50kgs in the back of the tray at least. |
#9 | |||
Cheers Jim
Virtuous Bogan (TM)
which generally have the same tray style as our utes.
perhaps with drag racing it makes bugger all difference, but general highway cruising I think it woudl improve economy having it up.
in my ute (which i had to sell for an extending family) there was a huge depression in the torneau cover right at the back suggesting the tailgate(and or tub) was stopping air from exeting cleanly. im assuming it would depend on speeds and exactly the shape of the ute also.
#12 | |||
Location: Working, chasing after my daughter and working
With tailgate up the air flows over the roof down onto the tray hitting the tailgate spiraling back creating a eddy of air which is creating drag, dropping the tailgate the air goes over the roof down through the tray and out the back no drag. Myself always run with tailgate down even better off. |
windsor user
they were new F150's....
was very interesting i'll say.... |
#14 | ||
If you run with the tailgate down it should be less resistance, but added bonus is..............
the paint chips you get in the tailgate will result in less weight, any one know how much a paint chip would weigh???? ![]()
#15 | ||
Right out sideways
but more drag if its down
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
#16 | ||
AS IT SAYS.....
The test on myth busters concluded that with the tail gate up the 'vortex' of slow moving air was created in the rear allowing the faster moving air to glide over it aerodynamically. With the tail gate down there was no or little vortex however the faster moving air puhed right down on the rear of vehicle, as a result excess force was generated to the rear axles making the car not as "efficient" due to this.
The purpose of the test was to find out which was more efficent, up or down in an open road environment. However ...Drag racing ...well the extra down force on the rear axle with the tail gate down=quicker times to me. So each purpose to its own gain. ![]() ![]() |
#17 | |||
Peter Car
#18 | ||
3 Pedals R Better Than 2
Their trucks were also dual cabs with only a short rear tray. It would have been better to see how a traditional long tray would go as the aerodynamics would be slightly different.
Would be intersting too see separate results with torneau or hard cover. I think they ended up driving 600 miles (almost 1000km) to run the fuel tanks dry and then there was only about 30-40 miles difference. So on a quick 1/4 mile squirt, I reckon there wouldn't be much in it. |
#19 | ||
So maybe it comes down to this, keep the tailgate up for less drag VS keeping it down for better traction.
Im guessing you ute owners would opt for the traction?? ![]() Cheers Jim ps. would like to see some back to back timed runs.
#20 | ||
I used to race mine with the tarp on, never tried the tailgate trick as everyone was getting stones flicked up on the return road from sticky tyres
#21 | ||
Bolt Nerd
What if you had a "variable" tailgate (ala Porsche Whaletail) that changed angle according to speed? (just watch your fingies when it closes automatically)
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner ![]() |
#22 | |||
Now a FG XR8 in Nitro
Nitro XR8 6 Speed Manual - SS Inductions Growler, Herrod Headers John Bowe exhaust 0-60kph 2.46 secs |
#23 | ||
Oops, I slipped....
Why not keep the hardcover fitted?
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
#24 | |||
Back on the road
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
#25 | ||
has anyone ever compared the difference running with and without the hard cover??
#26 | |||
#27 | ||
i think if i ever get to running my ute down the strip id leave it on, just so i get an idication of what id run in full street trim, probably leave the motorbike ramp kit and tie down kit bolted inside the tub too,... mainly coz id be too lazy to pull them out,...
#28 | ||
congratulations lowride is exactly for that reason is reccomended that the tailgate be dropped nothing to do with traction if stone chips are a problem slow down on the return has been like that for 20 years and will never change if that is a problem lift the gate before returning oxford scholar not required for that idea power to weight is great idea for super stock but these are all street cars prostreet is illegal here unfortunately also on going through scrutineering it should be told to you that the tailgate is normally down during the run it's the same principal as windows are to be up also these issues are all to do with RULES OF RACING if that is understood....also if that bike rack is not secured to the floor you would be pulling it out before you got anywhere near the track let alone run down it ....
![]() Last edited by MIEF9640; 10-06-2006 at 08:45 PM. Reason: forgot part |
#29 | ||
dunno if you've ever seen the factory motorbike ramp kit, but the mount point for the bikes front wheels stays bolted to the front of the tub, the actual ramp stays in my garage....
#30 | ||
Ute Forum Moderator
I saw most of the segment, typical mythbusters really. As Trublu351 mentioned above they were big F150 crew cab utes which would minimise any tailgate effect (high cab and short bed compared to our utes). I remember seeing a concept truck years ago that was a hybrid or similar, it had a hard cover on the rear half of the bed for aero reasons which would contradict the mythbusters findings.
