Old 09-06-2006, 12:51 PM   #1
ef_classic
ef_classic's Avatar
Default Sony Head unit Question.
Hi,
I recently got a new sony cd player for my car.
I was told that i need to purchase a bracket for it to fit into my EF2 Falcon.
Is this true???
ef_classic is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2006, 12:54 PM   #2
LTDHO
The one and only
LTDHO's Avatar
Bracket? Not to mount it as it will be standard DIN size.
You might be able to get an adapter plug to make wiring easier, that's it.
Tuned by CVE Performance
Old 09-06-2006, 01:01 PM   #3
harpsta
I6 LICKS
harpsta's Avatar
the H/U will be the right size but you do need a bracket to mount it in. I just cut and drilled the stock bracket to bolt the last 2 sonys I did in. You will need a tamper proof torque spit tool to get the old one out.
harpsta is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2006, 01:26 PM   #4
Damo
just use the brackets off your factory Headunit.
Old 09-06-2006, 02:36 PM   #5
harpsta
I6 LICKS
harpsta's Avatar
You can't just use the factory bracket's with ef/l you need to mod the bracket. Cut the back end off or belt it flat with a hammer and then drill new holes in the right spot.
Old 12-06-2006, 08:35 PM   #6
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
i got my car with a kenwood h/u and when i switch to the sony i just needed to use different screw holes on the slide bars which allows the unit to slide in and out of the main bracket once the security (5 point star) screws are removed.
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
