Old 15-06-2006, 09:56 AM   #1
max
LWBforME
max's Avatar
Default Letting of steam
My car was pumping out steam like Puffin' Billy this morning. OK it was 0.2º and stopped at the traffic lights the steam enveloped the car. I notice other LPG cars steam a lot more than petrol cars. Anyway, my real point is I think I've cooked my fuel pump by being a dumb-*** and letting the petrol tank go to empty 'cos of the prices I just get gas, stuff petrol! I put in $15 of juice and when I switch to petrol– no go! I have been told this is a thing that can happen the fuel pump, located in the tank apparently will burn out? Sheez, how do you fix that!!!???? Is there a way to test it is really a screwed pump? BTW its a 3.9MPFI.
max is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2006, 10:13 AM   #2
EBII Fairmont
EBII Fairmont's Avatar
Recently when I installed gas on my car, the dude that did it said the car must always have a quarter of a tank of petrol. I don't get why it needs it if your not running it on petrol.
EBII Fairmont is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2006, 10:35 AM   #3
max
LWBforME
max's Avatar
Well its because apparently to start the car even on gas it takes a drop of petrol to get it going first off. Also as I say if you let the tank dry you can dehydrate your petrol pump??? My issue is that because she's not dragging fuel into the rail, it has to start on gas and that takes a fair bit of cranking!
Old 15-06-2006, 11:07 AM   #4
GOLDIE
The eletric fuel pump is inside the tank and on most cars fitted with gas the pump is still running even when you are switched to gas so if you run out of petrol the pump runs drier and burns out.
10 t0 15 litres of fuel is cheaper than a fuel pump.
Ian
Acid rush txr6,5.1 surround sound,350 rwkw's,major interior trim work.
GOLDIE is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2006, 02:59 PM   #5
Fairlane
V8 Powaah
Fairlane's Avatar
You got to keep petrol in the tank or you burn of the pump.
As for the steam thing, its normal, LPG cars have hotter exhaust temps.
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2006, 03:27 PM   #6
LTDHO
The one and only
LTDHO's Avatar
Go straight gas!
Then you will not kill your petrol pump!
Tuned by CVE Performance
