Old 14-07-2006, 04:26 PM   #1
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Noise problem
Hi all,
The boys Eb is making a high pitch squeal noise after I fixed the front end. Its quite when at idle, put when he drives it it make the noise, Sounds like its coming from the fan belt. What have I done wrong?
Uncle Ken
Old 14-07-2006, 04:49 PM   #2
XRated
Shoot.
XRated's Avatar
Does it happen more-so when you put load on the electrical system? Could be as simple as a loose belt.
20V Turbo
Old 14-07-2006, 05:40 PM   #3
Bluemist
Bluemist's Avatar
spray a bit of CRC on the belts
Bluemist is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 06:12 PM   #4
Fairlane
V8 Powaah
Fairlane's Avatar
Seized fan belt tensioner ?
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 06:57 PM   #5
efmont
Sounds like a loose/worn belt to me, usually the alternator belts go on them. try tightening it first and if it still does it then buy new belts for it.
efmont is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2006, 07:43 PM   #6
sphell
sphell's Avatar
could also be the bearings in one of the idler pully's. They always go. And btw, it's not a good idea to spray CRC on the actual belts, it will only make them slip. Spray it on the center of the pully's where the bearings are.
Old 15-07-2006, 05:19 PM   #7
Uncle_Ken
Uncle_Ken's Avatar
Thanks for the thoughts guys. The EB lights went out last night. My son called me up, I had to jump start it to get it home. Luck for him I picked up an alternator from the wreckers when I was replacing the water pump. I changed out the old one and now everything seems OK. I have just go back from taking the car for a long run. No belt noise, battery seems to be charing. Xrated I put on new belts last week. Hope fully the replacement alternator will do the trick.
Uncle Ken
