Old 24-07-2006, 08:45 PM   #1
Sweet_EL_
Default Has anyone done it??
Ok I'm looking to if it can be done at the moment...
So can you turn the throttle body around so its faceing the "right" way?? Is so what things do you have to look out for??
any pics of this been done would be gate..
thanx
John
Sweet_EL_ is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 09:07 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
trick xd has done it on his EL.
the DRIF6 has done it too.
not a cheap mod unless u can DIY.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 24-07-2006, 09:10 PM   #3
EFDream
XRR83D
EFDream's Avatar
Sorry to deviate from the topic but what would be the advantage of doing this to your throttle body? pardon my ignorance....lol
2003 BA XR8 Falcon - Lightning Strike
Mods: 18" GT's (Aftermarket), BF GT front end(FibreSports), Tint, Premo Sound, Leather, CAI, DBA slotted,
2007 Suzuki Swift - Pearl Red
Povo Pack
EFDream is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 09:12 PM   #4
Jason[98.EL]
Jason[98.EL]'s Avatar
trick xd will be able to answer that for ya efdream
[SIGPIC][/SIGPIC]
Old 24-07-2006, 09:47 PM   #5
needfordspeed
I'd also like to know this!
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 09:48 PM   #6
EFFalcon
Last warning
EFFalcon's Avatar
probably nothing apart from shorter path for the air to travel, woudln't heat up as much.
hence why i said it wouldn't be worth it unless u could do it yourself.
Old 24-07-2006, 09:49 PM   #7
EFFalcon
Last warning
EFFalcon's Avatar
hxxp://www.deleted link/pics/cruises/GOR2/P1010441.jpg
Old 24-07-2006, 09:54 PM   #8
needfordspeed
I see, can't see it making much of a difference at all perhaps trick_xd could shed some light on this?
Old 24-07-2006, 10:12 PM   #9
YLDTRK
Formerly GTP075
YLDTRK's Avatar
ford designed it like that for a reason. it would give a loss in torque due to the total intake length being shortened, not to mension a restriction with that corrigated pipe thats been used on that EL taxi. thats my 2cents
13 PX WILDTRAK brand new wheels and tyres for sale Pm me
YLDTRK is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 10:13 PM   #10
XRated
Shoot.
XRated's Avatar
Use an ED manifold :P
20V Turbo
Old 24-07-2006, 11:55 PM   #11
snypereb
[EBGLT]
snypereb's Avatar
Any particular reason you aint done it to yours john?
[EBGLT]
Old 24-07-2006, 11:57 PM   #12
EFFalcon
Last warning
EFFalcon's Avatar
I can't weld
if i could weld i'd deffinately consider it for when the cars turbo, but for now i'll leave it.
Old 24-07-2006, 11:59 PM   #13
snypereb
[EBGLT]
snypereb's Avatar
I can't weld
Fair enough!
[EBGLT]
Old 25-07-2006, 12:29 AM   #14
trick_xd
I build your wish list...
trick_xd's Avatar
TuffED
Yes that corrigated pipe is a restriction .. But i was only useing it to see if it would work .. The G.O.R. Day was the first run it had like that ..
As for loss of Torque .. No Way .. A few have seen my car and it goes very good for the crap box it is.
Sweet EL
Yes it is a very easy mod to do ..if you take off the top part of you manifold and use a hacksaw to cut it with. Turn it up side down and extend the throttle cable ( I cut 1 from the wreckers and just joined them ) there is no wait on a throttle cable But i did use 2 of the wire clamps just in case .. (I must see about getting a Propper cable)I have done a few of them now just stuffing around to get the angle right so it dose not hit the Bonnet .
Throttle Responce is Great there is no lag like you get from the E-Series and if you have your air (pod) filter in front of the tyre like i do it gets all the air it needs and the air flow to the throttle has no restriction.. As you know there are two 90* bends in the air pipe..
I did mine as i had a master plan .. That was forced induction .. Now i have gone away from that idea as it costs to much and there will be more problems doing it ..
I have allmost Finshed a Twin Throttle Body for Heljas and 1 for me as well. On testing on my car it improved my power and was a lot more responsive from 2,000 rpm
BUT my car is L.P.G. and i have had a run or 2 with heljas and there is nothing between the cars Mine has just a bit more legs up hills
If you realy want to see how it all works i have some good pics and can talk you through it very easy ..
I even have a spare 1 in the shed all done up .. Buts Its a special one just for my motor :hihi:
If it weren’t for physics and the law enforcement, I’d be unstoppable.
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 07:10 AM   #15
Sweet_EL_
yeah I wasn't sure if it would hit the bonnet or not. so it will hit if you leave it on the same angle as the normal way??
I'd love to see more pics...
Old 25-07-2006, 01:15 PM   #16
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
hey trick_xd, long time no see. would be very interested to know how much you would want for a twin throttle body setup.i would pay good dollars for one. PM me mate
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw)
2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned)
Mr_4.0 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 06:16 PM   #17
trick_xd
trick_xd's Avatar
HaHa Sorry M8 not yet :
O.K. I have had a few PMs about the twin T/b
and i will post pics when i have it all sorted as It dose not look to flash a.t.m. It will/should be Finshed in about 4/6 weeks with a dyno sheet as well
Old 25-07-2006, 06:41 PM   #18
Sweet_EL_
how did you go when you welded it back togeather?
I've been told by a few guys that it will bend it...
Old 25-07-2006, 07:31 PM   #19
trick_xd
trick_xd's Avatar
If the person that you took it to dose not know how to stop it then i would not take it there ..
Im NOT a welder I just muck around doing my own stuff so i can see what it dose or if it will work .
What I did was get a straight big bit of steel and drill the holes to suit the top of the manifold and bolt them together. Then i welded it and let it cool untill the next day then i unbolted it and put it onto my lower half and all is good .
If you was in Geelong i could knock 1 up for you in no time ..
Old 25-07-2006, 10:00 PM   #20
Sweet_EL_
well if this one doesn't work for some reason, then I'll prob get you to send me one... If I knew that you did these before I would of sent you mine to do.. Oh well you get that...
Old 27-10-2006, 06:43 PM   #21
Sweet_EL_
I'm finnaly going to give this a try myself, but I'm just wondering what welding rods would be best to use to weld it back togeather?
Old 27-10-2006, 07:29 PM   #22
Psycho Chicken
Psycho Chicken's Avatar
It won't have anything to do with torque. Yes lengthening the intake runners gives you more low end torque, but it doesn't matter what you do on the other side of the TB.
Old 27-10-2006, 07:31 PM   #23
Sweet_EL_
I just want to try coz I can, and I have a spare manifold lying in the shed... so y not...
Old 27-10-2006, 07:47 PM   #24
Psycho Chicken
Naw didn't mean you, I'm just too lazy to quote who I mean.
Old 27-10-2006, 07:58 PM   #25
DNKPWR
DNKPWR's Avatar
Looks like it too much effort...!! FOR little or no gain...
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
DNKPWR is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 08:08 PM   #26
Sweet_EL_
ok then
