Old 23-03-2005, 02:11 PM   #1
SSbaby
SSbaby's Avatar
Default Motor Hot Tuner
A really good read. It has a feature on edited versions of LS1-powered VZ SS and Boss GT Falcon. Both vehicles were edited and at dynoed at Street Tuna's workshop. The VZ SS ended up with 240 rwkw post edit while the GT dynoed even better at 258rwkw after tricking its PCM with the CAPA flasher! But it was the Holden with more impressive on-track performance... 12.7s, 0-400m while the GT was not far behind at 13.4s.
There's heaps of other good articles for both Ford and Holden fans, alike.
The Tuner version of Motor is the sort of mag that we enthusiasts have been screaming out for for quite some time. I'm glad someone is listening. Top effort, Motor!
SSbaby is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2005, 02:16 PM   #2
loxxr6
XB in parts...
loxxr6's Avatar
I have I think the first edition and its not a bad read.
From memory it had the APS XR6T Phase 3/ kit in it.
Old 23-03-2005, 02:37 PM   #3
XRQTOR
XRQTOR's Avatar
12.7-13.4 IS A BIG DIFFERENCE ON THE TRACK. The GT has an 18 rwkw headstart and loses by 7 tenth's. Does it show the 6o" times and mph for each car.
Old 23-03-2005, 02:50 PM   #4
SSbaby
SSbaby's Avatar
**post edit times quoted**
GT
A4
0-100km/h: 6.22s
0-400m: 13.41s @ 169km/h
SS
M6
0-100km/h: 5.56s
0-400m: 12.74s @ 176.5km/h
Old 23-03-2005, 03:35 PM   #5
Steffo
LPG > You
Steffo's Avatar
That GT seriously sucks... 258rwkW and it goes 0-100km/h slower then a stock example should? Either that or its got major traction issues... or maybe the driver...
The SS did really well though.
Old 23-03-2005, 03:53 PM   #6
Sox
RIP...
Sox's Avatar
Sounds about right to me, the GT is approx 150kg heavier than the dunnydoor.
Throw 2 people on board the dunnydoor, and watch it run 13.4 or worse.
Rick.
Oval Everywhere...
Old 23-03-2005, 04:22 PM   #7
SSbaby
SSbaby's Avatar
My intention was to gloat about a magazine that IMO is great reading... not so much focus on the relative merits of the vehicles tested. The end result of what was achieved with edit is what's important. Owners of both marques now have relatively cheap ways to increase performance without puting a hole in their hip pockets.
Some Ford owners have already seen the effective gains.
Old 23-03-2005, 04:24 PM   #8
FTE217
T3/Sprint8
FTE217's Avatar
Exactly right Sox, the Commy guys always crow about their off line speed and good luck to them thats what they got. Lighten up the GT to the SS weight then thats a true comparison.
What is the times and weight of the R8 anyone ?
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
"Don't believe everything you read on the internet. Abraham Lincoln"
FTE217 is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2005, 04:25 PM   #9
SSbaby
SSbaby's Avatar
OT: BTW, to Steffo and others,
There is a guy on the other forum with an edited Stato with 'only' 210 rwkw that manages 13.3s quarters on street tyres... again and again. Nobody believes his car could run the times claimed... until he produces the timeslip... and he doesn't care what anybody else thinks. Numbers aren't everything!
Back on topic...
Old 23-03-2005, 04:30 PM   #10
GT 8888
↑↑ USERNAME ↑↑
GT 8888's Avatar
I noticed that Motor were using a G-Tech to measure the times. Is that what they normally use?
NO MODIFICATIONS.....JUST IMPROVEMENTS
"I wasn't speeding officer...I was qualifying"
Originally Posted by 347_XR8
If the Grim Reaper drove a car....it would have to be that car!
GT 8888 is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2005, 04:40 PM   #11
SSbaby
SSbaby's Avatar
I thought the Correvit was the standard of all timing equipment? I was also puzzled when I saw the same pic.
Perhaps Mickey T could explain?
Old 23-03-2005, 04:49 PM   #12
SSbaby
SSbaby's Avatar
Have a look here at G-Tech's website...
http://www.gtechprosupport.com/support/
If you are getting strange results, the result in all likelihood is one of the following:
incorrect vehicle weight
mounting system not tightened, or cracked/broken (lots of vibration)
slope/grade in the road
severe vehicle vibration
wind (head or tailwind)
clutch slip, wheel slip, wheel hop, torque converter slop, bumps on the road
incorrect driving style
Old 23-03-2005, 04:50 PM   #13
ozzyjim
ozzyjim's Avatar
So let me get this straight, they took a stock VZSS, stuck on a edit and ran a 12.7?
Jim
ozzyjim is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2005, 05:06 PM   #14
ozzyjim
ozzyjim's Avatar
Also, the edit for the SS makes a MASSIVE 40+ RWKWS?
Jim
Old 23-03-2005, 05:37 PM   #15
EFFalcon
Last warning
EFFalcon's Avatar
haha, everyone complains about the GT losing by 7 tenths.
yet the GT was an auto and the SS was a 6 speed.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 23-03-2005, 05:43 PM   #16
SSbaby
SSbaby's Avatar
The gain for SS was 16 rwkw while the GT gained 21 rwkw. I guess the SS was healthy to begin with but what the figures DON'T reveal is the way the power (torque) is delivered.
Not forgetting that there's other things in a tune which we care not to talk about like the torque truncation. In the SS, if you bounce off the rev limiter it usually means you'll run a slower time; if you hit the rev limiter in a stock GT your head will virtually crack the windscreen such is the severity of it's intrusion! Btw, TQ Management on both edited cars was disabled.
Old 23-03-2005, 05:51 PM   #17
Steffo
LPG > You
Steffo's Avatar
Um... Auto is faster when drag racing :
Old 23-03-2005, 06:03 PM   #18
Racecraft
they call me Tibbo
Racecraft's Avatar
Back on topic...
Is that Voodoo by any chance? I have met him @ Willowbank before, I dont know the exact numbers mind you but he didn't strike me as a fairy tale teller
Old 23-03-2005, 06:15 PM   #19
SSbaby
SSbaby's Avatar
No, his nick is 'iwantahsv'. His car is bolt-ons only with edit.
If we compare LS1s to Boss' then I reckon the best way to do it would be to compare Stato to GT... that way we stop talking about the weight variable, which is significant and does impact on overall performance... but that's not GM's fault!
Old 23-03-2005, 06:17 PM   #20
Racecraft
they call me Tibbo
Racecraft's Avatar
Ahh OK I think Voodoo runs a Stato Luxo Barge too that also has bolt ons and an edit that cuts some respectable numbers considering the QLd climate at the drags...
So to agree with you entirely SSBaby the wieght is not the be all and end all it is how the power is delivered is just if not more important
Old 23-03-2005, 06:21 PM   #21
ozzyjim
ozzyjim's Avatar
wow, i cant believe the ss (250kw) makes the same power as most gt's at the wheels and only losing 26kw through the drivetrain! Then run a 12.7 at that! Considering its a 14 flat (according to motor)car standard that 16rwkw`extra must be something awesome!! I reckon all the holden boys at the private drag day with heaps more mods running the same or worse times would be mighty ****ed.
Jim
Old 23-03-2005, 06:41 PM   #22
sbutler
335 kw of goodness
sbutler's Avatar
Rick.
I dont think thats the point.
There compairing a $45000 SS.
Against a $65000 FPV. Just think if thay would have got a new Clubby and did the edit thing...No wait....we dont need to think about that.. :
Allthough at the Australian Muscle car shootout at the Creek, the Holdens didn't fair that well. So mabe it was a bit of driver error...... :
CAUTION!
STILL Contain's opinion's & fact's that may offend !!!
2012 GTP 213 black what was I thinking? NOW FOR SALE>>
http://www.fordforums.com.au/showthread.php?t=11439680
sbutler is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2005, 07:41 PM   #23
Sox
RIP...
Sox's Avatar
Only if it's setup for drag racing only, that is, short gears, slicks etc.
Most typical factory road cars run quicker times with a manual.
Rick.
Oval Everywhere...
Old 23-03-2005, 09:02 PM   #24
XRated
Shoot.
XRated's Avatar
Um... These aren't full blown drag cars :
20V Turbo
Old 23-03-2005, 09:03 PM   #25
Steffo
LPG > You
Steffo's Avatar
BA SSS tends to be faster/better then the manuals.
Old 23-03-2005, 09:09 PM   #26
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
he has been using them for years, i thought a race track is where you get your ET slip...
G-Tech pfffftttt
[SIGPIC][/SIGPIC]
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2005, 10:38 PM   #27
Bossxr8
Peter Car
Bossxr8's Avatar
Not for the V8's it ain't, the extreme torque reduction on the autos see's to that.
Old 23-03-2005, 10:40 PM   #28
Bossxr8
Peter Car
Bossxr8's Avatar
The SS is $51k, the GT is $61. Can you even get an edit for the Gen 4 yet.
Old 24-03-2005, 04:24 PM   #29
old_mate
Smash the Boost
old_mate's Avatar
Yes, but this GT had BOSS edit, therefore no torque reduction.
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2005, 04:37 PM   #30
Sox
RIP...
Sox's Avatar
Sure, but it still had standard diff ratio and a standard torque converter.
No question autos are better for drags, IF they are set up for drags.
Typical standard road cars will almost always do the 400m quicker with a manual. Only turbo cars may break this rule as they dont fall off boost during the gear change.
Rick.
Oval Everywhere...
