Old 10-08-2006, 08:03 PM   #1
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
Default Converting to straight gas research, a few Qs
Hi,
After seeing a Turbo XE run a 9 with an AU motor, im gonna convert to gas and P!SS this petrol crap off.
Ok, heres what i THINK i need, let me know if i am missing something.
1 tank
2 lpg converters (which brands will flow 300rwkw together?)
1 gas research throttle body 440cfm
2 high-flow lock off valves
gas filler and flexable gas line.
PRICES???
What else will i need? How will i go about the wiring? Can i simply use an output from a wolf3d to run/prime the gas?
Also, how do i go about isc? i see the gra TB doesnt have a slot for it?
Injectors and Fuel pump may be for sale soon.
Cheers.
Cars:
- Ford Ranger Wildtrak
- XY GT Replica
- XB Coupe Project
BOOSTDEF is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2006, 08:14 PM   #2
Qwikcorty
V8 Turbo Hoon
Qwikcorty's Avatar
if going gas, sell the wolf injectors, whole lot. that should get you a lpg setup and a dizzy with mech advance and boost retard ready to go.
Qwikcorty is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2006, 09:18 PM   #3
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
Yeh i was hoping to use the wolf for the ignition tuning, along with its temperature adjustments which are necessary up here in brissy.
I would like to keep coil pack too?
How efficient would that set up be? Would the ratios be accurate?
Cars:
- XY GT Replica
- XB Coupe Project
Old 11-08-2006, 02:12 AM   #4
EFFalcon
Last warning
EFFalcon's Avatar
ISC gets tapped in from under the t/b.
you're looking at about $3k for that stuff installed.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 11-08-2006, 10:06 AM   #5
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
Yeh 3k wouldnt be bad. Just have to find the parts. Anyone want to give me some part numbers/models which work well?
Cars:
- XY GT Replica
- XB Coupe Project
Old 11-08-2006, 10:54 AM   #6
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
also, if goin straight gas, make sure that you have a set-up for one of those little "valve saver" fluid bottles. help keep your engine alive.
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw)
2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned)
Mr_4.0 is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 11:00 AM   #7
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
I just got an e-mail from Gas Research about straight gas turbo. They told me to look at their Technical Resource section on turbocharging with their products.
Click here and then click Technical Support up the top of the page. As long as its a draw through application, according to them its OK, blow through they won't put their names to the product.
Carless
Old 11-08-2006, 12:53 PM   #8
EFFalcon
Last warning
EFFalcon's Avatar
most striaght LPG turbo setups i've seen using GRA gear has been blow though.
my cars going straight LPG (GRA) turbo, just a matter of time.
i still need to add a better LPG line and 2nd converter, but thats about it ;)
Old 11-08-2006, 02:24 PM   #9
Walkinshaw
Two > One
Walkinshaw's Avatar
erm, okay.......
Old 11-08-2006, 02:25 PM   #10
Walkinshaw
Two > One
Walkinshaw's Avatar
Draw through LPG, wouldnt want a backfire would you ????
