The EL AND EF had Hidden Cluster functions Digital speed etc
You had to hold the [MODE] button down while starting the car Is there anything like that with the BA-XT? |
interesting... i would like to know of all the features you can "unlock" on the BA's as well.
So far i have been told there isnt any :(
are there any in the AU
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
#5 | |||
There was something about this in the au tech section long time ago...hold button down for xsec gave digital speed and revs...hold for xxsecs gave digital temp etc.
FORD RULES OK The more I know ppl the more I love my DOGS. 2011 SY Territory Limited Edition TS 2000 AUII SE ute IL6 |
EMC-Benzenes Detailing
Im sure you can get digital speedo display on some models in place of the speed alert....
torque is your friend
Yeah there is something like that on the BA's but I can't remember how to turn the feature on.
Support Cystic Fibrosis Australia Learn about it here, donate and help the research into finding a cure and to provide services for children living with CF and their families. |
you gotta get your Ford dealer to WDS reprogramme your BA cluster to enable digital speedo reading. as i did last month.
What features did you lose in the process?
the average & instant fuel consumption readings are lost. however the DTE range is still there and also trip A meter.
i could be going 100km/h on the dial where the digital speedo shows exact speed which might be 96km/h.
#12 | ||
Merry Xmas To All
There is a "Police" mode available for the BA\BF Which gives you a digital speed reading in the trip computer display on the non-premium sound version of the cluster. But you forfeit most of the trip computer readouts. It has to be enabled via the Ford Service computer.
Temporary Australian
How many $$ would the above set the average bloke back?
#14 | ||
Merry Xmas To All
I would assume it's only about 15 minutes work, so in theory it shouldn't cost more than $30 or so. But don't quote me...
#15 | |||
Back where I belong
I cant comment on the cost of doing it on a Ford, however the same thing was and is available on the Comm's and I had mine switched over to Police Mode, and it cost me nothing...Just some ammo if you wanted to challenge your local ford Dealer for charging for the "privledge"
Regards Craig |
#16 | |||
Ex EF Futura Driver
So, you are expecting the dealer to book the car, get the tech to spend 1/4 to 1/2 an hour with a WDS worth thousands, and not charge you something for it? ![]() |
#17 | ||
Another mate got his VY Done for free
Although he was a salesman at the yard at the time! |
#18 | |||
Back where I belong
Regards Craig |
#19 | |||
Dual O2 sensors
On VS/VTs, dont you just hold a button down while turning on the car to get it to work? My brother in Law does it all the time to his fathers car..
Black 1990 300zx Twin Turbo 5 Speed Manual ![]() Blue 2004 Mini Cooper S 6 Speed Manual - Yes, thank you Amanda. I realise now that you updated my signature to include your car. ![]() |
#20 | |||
SV6000. Yum
#21 | ||
Anyway. Can this be done on cars with premium sound (trip functions on the ICC). So loosing something thats not in the dash doesnt really matter. i would rather see what the true speed is rather than the needle.
#22 | |||
Boss power
the diagnostic mode can be entered by using the following method 1) With the ignition key in the off position, turn the Ignition Key to the On Position. 2) Using the Odometer Button, Press the Odometer Button Down, then release 5 Times within 10 Seconds (Note : You must be very accurate with the timing. Depress the Button for 1 second, then release for 1 second. Do this 5 Times in 10 seconds) 3) Release the Odometer Button for 5 seconds. 4) Depress the Odometer Button for 7 Seconds. 5) Release the Odometer Button for 5 Seconds. 6) Depress the Odometer Button for 7 Seconds. You should now be within the AU Instrument Cluster Diagnostic Mode Within Diagnostic mode, there are 19 Diagnostic Screens that are available. At the moment we do not have enough information as to what all the screens actually are. To Exit the Diagnostic mode, Depress the Odometer Button for 11 seconds. Then these are all the modes. each time you press the button it will change the mode. Mode 1 Petrol in Litres (No Level Buffering) Petrol Sender Resistance (Unbuffered) 2 Coolant Temperature (Degrees C) 3 Engine RPM Vehicle Speed (KM/H) 4 Oil Pressure (Bar, 1 decimal Point) Battery Voltage (Volts) 5 Instant Fuel Consumption (L/100Km) Instant Fuel Consumption (x 0.1 Litres) 6 Fuel used since Trip Avg L/100 Reset (x 0.1L) This Value is used to calculate the Trip computer Average Fuel consumption L/100Km Kms Travelled since Trip Avg L/100 Reset 7 Buffered Fuel Tank Level (In Litres) Value used for Petrol Gauge Buffered Fuel Tank Lever Sender Resistance 8 Gear Position (PNRD321)
:the_finge BOSS 260+ :the_finge |
#23 | ||
SV6000. Yum
Are there any known existence of Ford software (outside of ford of course) that will let you view and log all this (and other) info an a laptop??
#24 | ||
Guy that posts stuff
Yes.. there is software that can read Canbus and I2C..
Forget which Ford used. I have heard of it being done. Most likely why there aren't any secret dash functions.. |
#25 | ||
Ford should incorporate some sort of technology in the cluster that will monitor & detect highway patrol vehicles incoming... that'll be so cool. press this button and that button and you get into this mode.
#26 | ||
If Digital speed is all that you get why get it done that way and lose the other 2 things like average & instant fuel consumption Why not buy a Dig ital Speedo you can get them on ebay get a Auto Elec to set it up for ya
#27 | ||
Dose anyone know a ford dealer in melbourne or machanic in ford that has a clue about reprogramming a bf cluster I’m not having much luck with the part changers
#28 | ||
Speak to auMatt .... he's on the forum ... and does cluster programming for B-series vehicle .... he's in Melbourne suburbs ... can't remember which one though ... but have had work done by him before with no issues.
