23-08-2006, 08:23 PM | #1 | ||
dropped
is it possible to put an el fairmont bonnet and grill on a xh ute? what would needed to be changed in order to get the bonnet to fit properly
23-08-2006, 08:25 PM | #2 | ||
rofl copter
u need to change the headlights and front bar
GQ patrol.
.... thats all |
23-08-2006, 08:28 PM | #3 | ||
I'm pretty sure it won't fit cos of the radiator support height.
23-08-2006, 08:29 PM | #4 | ||
E-Series Firemaker
You can't do it, they're a different length, and the shape of the bonnet at the windscreen end is still the same as an XD.
Alex
Automotive photography, fine art landscapes, portraiture Photo retouching and restoration
23-08-2006, 08:29 PM | #5 | ||
And that.
23-08-2006, 08:57 PM | #6 | ||
dropped
**** ey, oh well ford got lazy with the utes and pretty much just changed the engine to the 4.0i and updated looks
23-08-2006, 08:59 PM | #7 | ||
Last warning
yep, you're stuck with EF/EL XR or EF GLi front :P
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
23-08-2006, 08:59 PM | #8 | ||
dropped
what if ya chopped and changed the bonnet a bit? do you reckon you could get it to fit?
23-08-2006, 09:04 PM | #9 | ||
Last warning
anything can be done with a welder and filler :P
would probably be easier to try and adapt a grill to the XH bonnet and put on fairmont headlights/bumper.
24-08-2006, 12:18 PM | #10 | |||
cross breeder
Like xk-xf's?
http://www.ozfalcon.com.au/ |
24-08-2006, 01:24 PM | #11 | ||
Last warning
oh, the fairmont headlights won't follow the lines of the bonnet at the front, you'd need to modify that.
i've got pics of the differences in shapes if u want to see. (For the headlights)
24-08-2006, 01:59 PM | #12 | ||
BLUE OVAL INC.
I was led to believe that the XH actually was the first ute that got the different windscreen rake and so the fairmont stuff would fit.
Im sure it is different to the XG |
24-08-2006, 02:05 PM | #13 | ||
Last warning
the top end of the XH bonnet is still WAY different to the EF one.
if the fairmont bonnet was going to fit, ford would have used the normal GLi bonnet on the XH and not made a special bonnet for it.
24-08-2006, 03:51 PM | #14 | |||
BLUE OVAL INC.
Ok, i just vaguely remember at the time, somebody, somewhere, mentioning that the windscreen had been changed for the XH to closer resemble the sedan.. I stand corrected! |
24-08-2006, 04:09 PM | #15 | ||
Last warning
it may have changed, don't get me wrong.
how ever i don't think they're interchangable.
24-08-2006, 09:59 PM | #16 | |||
cross breeder
Like xk-xf's?
24-08-2006, 10:08 PM | #17 | |||
windsor user
as mentioned best bet with the bonnet would be to fit fairmont headlights and try and tack on the front edge of the bonnet where it butts up to the lights to your existing bonnet.... |
25-08-2006, 12:55 PM | #18 | |||
cross breeder
Like xk-xf's?
30-08-2006, 08:09 PM | #19 | ||
dropped
thanks guys but it sounds like its too much stuffin around for me
