Old 24-08-2006, 08:10 PM   #1
XRated
Shoot.
XRated's Avatar
Default Fastest E-Series I6 on LPG
With all this talk of petrol prices and the rebate, I was curious to know if there are any quick I6 E-Series on LPG.
I've been contemplating a straight-gas setup but I still haven't decided if it's worth it yet (considering changing cars mid-next year)... And I am aware of the XE with AU engine and turbo running 9s but I think I can assume it's had lots of money thrown at it!
Has anyone priced a SVI system on an E-Series? Is there a replacement LPG tank for the traditional petrol tank in an EA-ED sedan? I don't like the idea of losing boot space. Oh, and one other thing - will the fuel gauge on the factory cluster be able to show how full an LPG tank is??
20V Turbo
Old 24-08-2006, 08:58 PM   #2
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
i am also very interested in this, but what comp ratio can LPG go up to?
pete j
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2006, 08:59 PM   #3
XRated
Shoot.
XRated's Avatar
Ah yes, was going to ask that question too.
Also what's the go with aftermarket ECUs and BBQ fuel?
20V Turbo
Old 24-08-2006, 09:47 PM   #4
cringe
cringe's Avatar
Cool gasresearch
funny.. i was thinking the same thing.. like the look of the gas research setups.. hmmm.. nice..
Ford EA/EB1 Falcon 6cyl, Centrefire, 3sp/4sp Auto $1036.50
Kits include the following :
Throttle Body, Convertor, Lock-off valve, Adapter, Electric Primer, Brackets, Gaskets, Linkages, and Closed Loop Processor System and Idle Speed Control System where applicable.
sounds good.. and with 2000 cashback works out pretty good.
'08 FG XR8 Ute / Nitro / Manual / XR Sports Pack.
cringe is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2006, 09:53 PM   #5
Racecraft
they call me Tibbo
Racecraft's Avatar
Dont forgot to add the 1" vapour line, brass fittings, instalation and tuning... You won't get any change from $2500
Old 24-08-2006, 10:17 PM   #6
XRated
Shoot.
XRated's Avatar
Cringe, that looks like a neat setup. Is that price just an upgrade for a Falcon on dual-fuel or something? I guess you need to add in a tank and all the other stuff Racecraft mentioned. I also see it's for a CFI but you've got pics of a BBM setup...
20V Turbo
Old 24-08-2006, 10:22 PM   #7
Racecraft
they call me Tibbo
Racecraft's Avatar
that price quoted is just what they call an under bonnet kit
Old 24-08-2006, 10:26 PM   #8
XRated
Shoot.
XRated's Avatar
So really it'd be the cost of the initial conversion and then another $1k for the pretty stuff?
20V Turbo
Old 24-08-2006, 10:32 PM   #9
Racecraft
they call me Tibbo
Racecraft's Avatar
yea give or take a couple of hundred for 'x' brand of convertor that you installer would normally fit
Old 24-08-2006, 11:12 PM   #10
needfordspeed
Quickest E-series on gas I can think of right now would probably be John's car, can't really think of anything quicker on gas.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2006, 11:47 PM   #11
snypereb
[EBGLT]
snypereb's Avatar
I wanna see scott gthofan give his car some real stick he runs gas! He has got extractors and exhaust and a manual!!
[EBGLT]
Old 25-08-2006, 12:05 AM   #12
trick_xd
I build your wish list...
trick_xd's Avatar
Just stay with the IMPCO stuff and you will be right .
GRA stuff is good but its hard to find some one that knows how to tune it.
XRated yes if you want your gas gauge to work of your dash petrol gauge it is easy to do to "interface" it .
a gas conversion is $2090 a.t.m. but we have been told that they will be going up maybe a extra $200 or so. as for aftermarket e.c.us they will do nothing to the gas.
EB pete comp ratio can go as high as you can gas likes high compression .
as for how quick .. I have not run my down the qtr but is good enough ..
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2006, 02:34 AM   #13
rawan05
not sure bout the xe but theres the xf called ezi-10 from vic. as u can probably tell it does 10s, and does them on gas and turbo crossflow engine.
rawan05 is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2006, 02:40 AM   #14
rawan05
and u can see it on fullboost on features second page
Old 25-08-2006, 03:11 AM   #15
EFFalcon
Last warning
EFFalcon's Avatar
mines the quickest TESTED eseries i think.
(aslong as we're talking n/a)
i'm fairly sure everyone else has done their times on petrol.
GO ME!
15.9 WINNAH!
Don't think it'd take much to beat mine
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 25-08-2006, 03:18 AM   #16
Smoked
Burnin Rubber
Smoked's Avatar
GO ME!
15.9 WINNAH!
And yours is quick ta boot. Makes my AU looks slow as, not that its hard to make an AU look slow.
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2006, 03:19 AM   #17
EFFalcon
Last warning
EFFalcon's Avatar
In my opinion there was more in my car, but i think i damaged the engine and it hasnt bee n the same since.
i'll be plenty quick on LPG soon enough
Old 25-08-2006, 09:27 AM   #18
oneredED
need more boost
oneredED's Avatar
GO ME!
15.9 WINNAH!
15.8X here (15.6 was petrol) I'd find the slip, but it's not like I can prove it was an LPG run :(
'94 ED Falcon GLi
Suspended by: kings, koni, pedders
Rolls on: 17" AJR Director's
Stops due to: bendix, DBA
Shifter connected to: T5 manual
Power from: ???
Interior: velour and woodgrain
Cost: stuff all :P
oneredED is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2006, 10:14 AM   #19
Kenaz
Kenaz's Avatar
I wonder if Simon ever ran his EA on gas at the drags? If so, it was probably pretty quick.
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2006, 10:50 AM   #20
niko
likes falcon's
niko's Avatar
i have that GRA overhead pipe if anyone is chasing one :p lol
www.carhubsales.com.au
Old 25-08-2006, 10:56 AM   #21
dansedgli
dansedgli's Avatar
18.9 in my LPG EB. :P
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2006, 10:59 AM   #22
niko
likes falcon's
niko's Avatar
my manual mockup ea would run low 16's on gas and that was on fuel timing never touched it when i put gra on it
Old 25-08-2006, 11:31 AM   #23
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
That XE is running 9s with an AU motor with a gas research 440 TB and twin converters.
It all seems simple really. :P
Cars:
- Ford Ranger Wildtrak
- XY GT Replica
- XB Coupe Project
BOOSTDEF is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2006, 12:30 PM   #24
EFFalcon
Last warning
EFFalcon's Avatar
looks like onereded's got the title.
but he's manual so thats crap
Old 25-08-2006, 01:24 PM   #25
Gubas
- BOOYEH -
Gubas's Avatar
Ask me in a week ;)
1993 EBII Fairmont Turbo T04e 7 psi
Gubas is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2006, 02:26 PM   #26
RAMD67
RAMD67's Avatar
I'm pretty sure I ran an 15.8x on gas with an auto up at heathcote with the ED XR6 I use to have will check slips tonight...I wish I never sold that car :
FG F6 310
Black with Brembos, Leather, Sat Nav, 19" Graphite Wheels & FPV Floor Mats...no mods needed for this beast!!...well maybe a tune..and then... :
RAMD67 is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2006, 03:38 PM   #27
XRated
Shoot.
XRated's Avatar
Hmm so a mid 15 is all that's needed? It's like the old N/A days! Maybe we'll see a straight-LPG turbo E-Series smash the title?
20V Turbo
Old 25-08-2006, 03:46 PM   #28
EFFalcon
Last warning
EFFalcon's Avatar
thats the plan Luke
Old 25-08-2006, 04:47 PM   #29
XRated
Shoot.
XRated's Avatar
Not if someone beats you to it
20V Turbo
Old 25-08-2006, 05:22 PM   #30
EFFalcon
Last warning
EFFalcon's Avatar
then i just have to beat them on the track ;)
