25-08-2006, 06:08 PM | #1 | ||
can anyone tell me if the gearbox from the gt v6 will fit behind a pinto, if not does anyone have a gearbox that would?
26-08-2006, 08:22 AM | #2 | ||
Flat out, NO. It has a completely different bolt patten. The standard Mk 2 Escort box is fine if you look after it (keep oil up to it as the rear seals always leak.) The GT Capri box from a 1600 has better ratios and bolts straight up to a pinto, but would require moving the gearstick hole further back. This is the same as a Mk 2 Cortina box, but this one has a different bell-housing and an hydraulic clutch.
26-08-2006, 10:21 AM | #3 | |||
vik...he's at work at the mo,drop us a pm.... |
