Old 28-03-2005, 11:14 PM   #1
neb
hibernating
neb's Avatar
Default EA-ED pod filter setup
First off this was not my idea! Calv did this first and sent me pictures and it looked pretty good so I thought it would do it. I've always had trouble thinking of how i could do a pod setup using the eb airbox (most people seem to change to ef/el setups).
This is my 4th air intake setup and gotta say its the best so far.
My first setup was a just a pod filter connected to the end of the airbox pipe sitting in the hot engine bay. Seemed to improve throttle response but lacked power.
Second setup pod filter directly on the end of throttle body. Further improved throttle response but still lacked power (sucking in more hot air).
Third setup panel filter setup using the bigger xh snorkel and a bmc panel filter. Not as much throttle response as the pod but seemed to make power actually sucking cold air in.
Now here is the 4th setup. I've pulled out the old k&n pod filter and attached it to the end of the airbox pipe. I've then made a hole in the side of the airbox and also had to file a few ribs in the airbox so the pod filter can fit inside. From where the airbox pipe originally hooked up i've used this to run a flexible pipe down to under the car to get more cold air. the airbox lid fits ontop nicely with the xh snorkel still functional. The cold air pod filter setup seems to be the best of both setups with good throttle response and making power sucking in cold air, and also getting the deeper exhaust note and induction noise that you get when using a pod. Also it still looks like a factory setup which is good.
Of course none of this is dyno proven and just based on what i can tell from driving the car.
Heres some photos. Thanks calv for showing me this setup.
what it looks like with lid on
pipe under the car
pod in airbox
pod in airbox again
different angle of pipes
neb is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2005, 11:18 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
don't look to bad actually.
fits in quite well.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 28-03-2005, 11:22 PM   #3
niko
likes falcon's
niko's Avatar
only bad thing i see bout it is the original ribbed intake pipe that usually sits on bottom of box is ribbed=which means slight restriction compared to a smooth lined pipe
www.carhubsales.com.au
Old 28-03-2005, 11:23 PM   #4
MickyB
Get in the ring!!!
MickyB's Avatar
Looks good, I might give that one a shot.
FG MKII XR6T - Tuned by Pit Lane
MickyB is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2005, 11:31 PM   #5
neb
hibernating
neb's Avatar
One thing i should mention is be careful with clearance of the throttle body with the pipe that goes to under the car. I had it in a decent position but it slid down a bit and my throttle got stuck. The car reved up to 6000rpm between changing gears and I lost my power steering belt!! Fixed that problem with a couple of cable ties lol.
Regarding ribbed pipes.. I actually found it pretty hard to find decent pipes. Bunnings I couldnt find anything. The new pipe is actually a "performance intake" pipe from autobarn lol cost me $20 !! It's ribbed on the outside but actually quite smooth on the inside. Wouldn't mind replacing the original one if I can find something decent to use (i'm not buying another autobarn pipe)
Old 28-03-2005, 11:34 PM   #6
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
That Cold air pipe is in the same position i had my first setup.
I ended up just making a box and getting a steel intake pipe bent up.
looks ok.
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2005, 11:50 PM   #7
neb
hibernating
neb's Avatar
Yeah I've seen pics of your setup Kerry it looks pretty good. I'm not really motivated (or skilled) enough to make my own box though. Plus this setup took me only about 20-30mins to do.
Old 29-03-2005, 07:44 AM   #8
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
Thats fair mate, but it doesnt take mach skill to make my setup.
Kerry
2008 MA XR5 Mondeo
Old 29-03-2005, 10:41 AM   #9
MickyB
Get in the ring!!!
MickyB's Avatar
Got a link to a pic Kerry? I feel I need some 'cold' air.
Old 29-03-2005, 06:08 PM   #10
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
Looks great
Was about to say the XH snorkel was not going through the air filter, but then I looked at the pic properly.
Daily driver
98' AU 349ci Fairmont Ghia on LPG
Other
93' ED 5spd 4.0L NA Fairmont
13.75 @ 101mph
V8 Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2005, 06:49 PM   #11
calv1234
After putting that tube going down the bottom i noticed that i had lost throttle response.. If i have just the thinner tube going straight down under the airbox and just below the bumper.. it goes alot better..
I'm guessing the black tube heats up too much and the cold air goin through it goes hot..
calv1234 is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2005, 08:15 PM   #12
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
Heres a pic of the box.
http://www.fordforums.com.au/attachm...tachmentid=627
Kerry
2008 MA XR5 Mondeo
Old 29-03-2005, 09:32 PM   #13
StarkEA
Ill get picks of mine b4 i put it all back together... ive got a rampod in box, with induction from front bar. I used the same piping from auto barn, its ribbed on the outside and smoother (not totally but good enuff) on the inside. will post in a day or so..
Ray
StarkEA is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2005, 10:28 PM   #14
needturbo6
ooga-lagga-ligga-lagga
needturbo6's Avatar
neb- thats gotta be the best eb air intake ive seen, doesnt look too hard to make and uses the stock airbox. when i get the money ill be doin mine that way. Good work!!
needturbo6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2005, 01:35 AM   #15
MickyB
Get in the ring!!!
MickyB's Avatar
Your setup also looks good Kerry, but is that a flat piece of material on the top (with Rush written on it), or did you bend it into position? It's kinda hard to tell in the photo, but it does look flat, although I'm not sure. Also what material did you use on the side part of the box? Does it keep the heat out well?
Thanks
Old 30-03-2005, 10:05 AM   #16
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
Its flat, the airbox is carbon fibre, i will get some more pics later today.
Kerry
2008 MA XR5 Mondeo
Old 30-03-2005, 10:18 AM   #17
neb
hibernating
neb's Avatar
cool it would be good to get some more pics.. i wouldn't mind doing something like yours eventually kerry.
where do you get carbon fibre sheets from? was it easy to cut to the right shape? did you need to drill holes to mount it all? is the bottom of it sealed or does it suck air through the holes underneath and around the headlight area?
Old 30-03-2005, 10:54 AM   #18
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
I have made the box's aout of 6mm perspex aswell before.
I got the CF from AWC through JR.
I used a diamond wheel in my dremal to cut it.
No holes drilled.
There is a 3" hole in the inner guard and a pipe running down behind the ABS module, to the hole in the front bar.
Kerry
2008 MA XR5 Mondeo
Old 30-03-2005, 11:01 AM   #19
neb
hibernating
neb's Avatar
cool sounds like it would work pretty well, i think the bad thing about my setup is that the pipe goes backwards a bit.. which means the air goes into the pipe but then has to flow back towards the front of the car.. plus being close to the engine the pipe gets a bit hot. but still seems to be working better then previous setups i've had.
hmmm dremel would be handy.. to make the hole in my airbox i had to use a drill bit with a circular cutting thing on it and drilled a few holes with that to get the basic shape then file it out a bit and also file the ribs in the box. dremel would of made it alot neater.
Old 30-03-2005, 11:07 AM   #20
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
Yeah the tool i have is a Ryobi one copy of a dremal ate 1/3 the price.
I also have the box lined with neopreen.
Kerry
2008 MA XR5 Mondeo
Old 31-03-2005, 02:25 PM   #21
asian_warrior01
that some nice customizing work got to say very nice
asian_warrior01 is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2005, 02:44 PM   #22
JUZXR8
Hmmmmm
JUZXR8's Avatar
i really want to get a cold air intake for my EA but i really lack the coordination and skill to build one myself and not totally screw it up, do you guys know anyone who might be able to give me a hand? i live in the northern suburbs or melbourne
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2005, 02:52 PM   #23
neb
hibernating
neb's Avatar
you should just give it a go... if you stuff up.. the worst case you have to go to the wreckers and buy another airbox or something.. not a big deal
Old 31-03-2005, 02:58 PM   #24
JUZXR8
Hmmmmm
JUZXR8's Avatar
yeah but the problem is its centerpoint
Old 31-03-2005, 06:44 PM   #25
Brnesy
DVE
Brnesy's Avatar
try using pvc condute heat bended i used it at one stage worked awsome with heat wrap around it stoping heat from comming in, if only i didn't go thru that really really raelly raelly big puddel......
anyhow a new bottem end later and it was all fine
Brnesy is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2005, 06:59 PM   #26
niko
likes falcon's
niko's Avatar
LOLLL at puddle!
Old 31-03-2005, 07:03 PM   #27
Brnesy
DVE
Brnesy's Avatar
just cause i failed school ... (well actualy i didn't but i still can't spell for crap) doesnt mean u have to bag me
Old 31-03-2005, 07:48 PM   #28
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
i think he was laughing about the outcome, not the spelling
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2005, 11:29 AM   #29
StarkEA
Default My setup
Hi guys, just got pics of my 5 minute job...
Easily done, bored new hole in bottom of box, already had hole in engine bay cut out, got red pipe through the original hole in airbox lid (very tite! had to screw it in) attached filter setup to that, attached all the top half to my intake pipe, had to srew the piping into new hol at bottom, then through the hole in wheel arch, then fix it so that it sits nicely at the hole in front bar....
As i know it, no engine bay air get in, completely sealed enclosure... (original hole in airbox now has piping cap on it, in pic i think just had racetape...)
Rayos...
Eveything is so tite, its like 1 big peice, so this is how it goes on and comes off!
Ciao
