Old 29-03-2005, 02:03 PM   #1
jedaarr
jedaarr's Avatar
Location: Nowra (Southcoast) N.S.W. Beutiful beaches no smog & plenty of grog & yes that is my dog.
Default Ea 5 Speed Cfi To Mpi Eec-1v Help
I Have Just Converted A Manual T5 Ea Cfi To Mpi Injection.
The Donor Was Ea Auto Ghia Parts Car, So I Had Everything I Needed.
Problem Is I Dont Have A Ea manual T5 Eec-1v Computer.
Ford Tell Me They Are Different But Without A Vin Number From Say A Ea S Pack Mpi T5 Manual, They Cant Give Me The Model Code For The Eec-1v Computer.
The Donor Car Was Without A Eec-1v So I Cant Trick It To Thinking It Is A Manual.
I Found A Cfi Conversion On The Forums And Someone Had The Codes
Posted But The Hell I Cant Find It Now,i Have Spent Hours Trying To Find Out On The Net Searching To No Avail.
Help Would Be Most Gratefull.
jedaarr is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2005, 04:19 PM   #2
Walkinshaw
Two > One
Walkinshaw's Avatar
Just head on down to the wreckers and grab a 3speed or 5speed EA MPFI ECU.
Old 29-03-2005, 04:55 PM   #3
jedaarr
jedaarr's Avatar
Thumbs up
musss tu beeeen ****sd, anyway you cant use a auto eec-1v for max performance , as the fuel injection codes are different between auto & manual, there are vastly different code out signals to manual mpi engine management, compared to auto mpi : engine management.
i will use a auto eec-1v if i cant find codes for a manual.
but thanks for your help.
Old 29-03-2005, 05:45 PM   #4
Low Na
Cruisin in my EL
The ea mpfi 3 spd ecu will run a 5 speed with no problems what so ever (and vice versa for that mater).
Low Na is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2005, 07:28 PM   #5
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
my car made 117rwkw with an auto mpfi ecu (ea) and i've had no other problems with it being manual using the auto ecu...
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2005, 07:34 PM   #6
SWOOP
XRSVO
SWOOP's Avatar
I also recently did the above and used a series1 3 speed ecu ,went hard and not one prob.
SWOOP is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2005, 07:57 PM   #7
jedaarr
jedaarr's Avatar
yesterday i installed a efi eec-1v out of a auto.
the car is now running perfect, idle is a1, and it pulls much harder, the wrecker told
me they have done many conversions auto to t5 manual and never changed the
eec-1v, only if it was cfi to start.
so you guys were spot on.
Old 01-04-2005, 10:49 PM   #8
SileNceR
SileNceR's Avatar
glad it's all good
enjoy the mpfi setup, it sure makes a difference, eh
211RWKW EA
Old 04-04-2005, 06:12 PM   #9
jedaarr
jedaarr's Avatar
how do you get the reversing lights working, since i changed to the auto eec-1v
i no longer have revesre lights, is there a special way to rewire somewere in the harness.
Old 04-04-2005, 06:48 PM   #10
SWOOP
XRSVO
SWOOP's Avatar
um thats one thing I didnt check hehe ,so Im no help for ya there
Old 08-04-2005, 04:45 PM   #11
jedaarr
jedaarr's Avatar
i found a wire had come out of reverslights, the garnish was ea, i modified it to eb & and had to rewire it to work. reversing lights are working a1 , i was wrong thinking it was the eec-1v being auto.
