Old 02-04-2005, 09:47 AM   #1
AUII_Forte
AUII_Forte's Avatar
Default Sqeaky Brakes
Hey guys,
I'm having a little bit of a problem with the front brakes on the EF. Ever since I had the calipers off to change the springs, the front brakes squeal and sqeak unless my foot is ON the brake. I have pulled everything back apart and cleaned it out and sprayed a bit of WD40 around, it seemed to work for about half an hour then the problem came back. Does this sound like a seized caliper or something?? Any ideas on how to fix it, it's extremely embarrasing! lol
Daniel
2003 Narooma Blue BA XR6 5spd Manual.
Pacemaker 4490 Extractors
2.5" Exhaust
High Flow Cat
SS Inductions "Growler" CAI
Underdrive Pulley
Mal Wood H/D Clutch
Custom Tune
18" XHP Sabre's
12" Kicker Sub
169.2 rwkw
AUII_Forte is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2005, 10:18 AM   #2
Psycho Chicken
Psycho Chicken's Avatar
You had the calipers off to do springs? Eh?
Pull them apart, clean the lot with proper brake cleaner and lube the slides with copper lube.
Old 02-04-2005, 11:11 AM   #3
INJECTED_250
Custom user title
INJECTED_250's Avatar
are the steel shims still in place where the pads slide... make sure these are still there.. As rob said pull the slides out from the caliper and use either the copper lube, even htb grease if u have none of the other.. ive seen even rubber grease work good. U may find one of the slides is stuck VERY common. Also wd40 has no place near any brake set up, the heat from the brakes will evaporate it quick as
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2005, 11:34 AM   #4
AUII_Forte
AUII_Forte's Avatar
Thanks for the tips guys. The shims are still there, I made sure of that. The WD40 wasn't to stop the squeak as such, I was trying to free up what ever is stuck.
Just went to supercheap and got some brake cleaner and some of the red stuff to put behind the pads. I'll get some grease and have a crack after lunch and see what happens.
2.5" Exhaust
High Flow Cat
Underdrive Pulley
Mal Wood H/D Clutch
Custom Tune
18" XHP Sabre's
12" Kicker Sub
169.2 rwkw
Old 02-04-2005, 03:06 PM   #5
AUII_Forte
AUII_Forte's Avatar
Seems to be ok now, I pulled the slides out with great difficulty and cleaned them and greased them all up, they now move nice and freely. I also put that red stuff behind the pads and it seems to have done the trick.
2.5" Exhaust
High Flow Cat
Underdrive Pulley
Mal Wood H/D Clutch
Custom Tune
18" XHP Sabre's
12" Kicker Sub
169.2 rwkw
