20-10-2006, 09:10 PM | #1 | ||
I'm currently looking at making a short shifter for my EF. I've taken the gear stick out and found a rubberized mount where it joins to the gear box. I was wondering what the pros and cons of having a solid mount (metal)..... :eclipsee_
20-10-2006, 09:31 PM | #2 | ||
Tuned @ Pitlane Frankston
Umm, underneath that shifter is a ballbearing type linkage that goes into the gearbox.
I can't see any advantage to a solid mount?
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
20-10-2006, 09:47 PM | #3 | ||
I'm sure someone told me that solid mounting it is noisy....could be wrong though.
21-10-2006, 02:36 AM | #4 | ||
EBII XR6
^^sound like that could be true, you'd have to find out for sure tho.
EFXR65spd: when ya finish post pics and tell us how ya did it. i want to know!!
DEVLXR
21-10-2006, 02:02 PM | #5 | |||
21-10-2006, 02:16 PM | #6 | ||
never enough power
I just though it was there to reduce vibration from the box? The selector will still be mounted by the same 2 little bolts so I don't see how it would improve or hinder anything.
EA Fairmont Ghia sleep: EA bottom end, AU tickford XR6 head JMM DEV 5, Race series headers, 5-speed manual, 3.7 LSD diff, sports suspension, sports brakes, all rapped up in a 89 champaign coloured falcon gl shell. |
21-10-2006, 02:55 PM | #7 | ||
It will probably make your shifting more direct, but also more notchy and you will get more transmission noise up through the shifter, which you have said you dont care about.
Something I have noticed is that the rubber insulator you are talking about seems to differ between vehicles - I've driven some E-series where the shifter feels like the bolts are loose, even though I've just tightened them, and others which feel VERY direct...I suppose the amount of improvement you see will depend on if you are starting with a squishy insulator or a hard one... |
21-10-2006, 04:19 PM | #8 | ||
likes falcon's
if you have ddecent rubbers you shouldnt notice a difference
www.carhubsales.com.au |
21-10-2006, 05:02 PM | #9 | ||
Mine is a solid mounted BPT short stick. does the job. It is a bit louder than rubber mounts, but it feels so much more solid and I love it. I will see if I can find some pics where someone has done it as well.
2002 Suzuki GSXR1000: Yoshi pipe and cosmetic enhancements only. 10.7 1/4 mile 1995 EF XR8: Pacers, 3" all the way, stereo & Vortech V2=297rwhp, 13.5 @ 105mph 1/4 mile Its not a TICKWUMP, its the TICKWUMP |
21-10-2006, 06:06 PM | #10 | ||
Tha Stah
Ive got a solid mount gear leaver...
Pros of Solid: Easier to find gates, easier to change, better for the 1/4mile, dont wear out. Cons of solid: Noisier, rougher sliding in and out of gates (on the hands) no difference for the gear box itself. Pros of Rubber: Smoother changes into gates, stock, quiet. Cons of Rubber: They wear out, harder to find gates. Well, thats my take on it... I perfer the solid heaps more, Though I did mention noisier, you dont notice it unless the car is off... I also have a shorter shifter. Hope this has helped, SupahStah
1998 EL XR6: |Custom POD Filter Intake, Pacemaker 4499's, Redback 2.5" Catback - straight through tail pipe.|. 113,000kms. Best E/T: |15.080 @ 91.03mph | R/T: 0.848 | 60': 2.175 | 660': 9.674 | Colour: |Regency Red.|. Soon To Come: |Largish Cam + Chip| ETA: *When the bank account is ready * |
24-10-2006, 08:47 PM | #11 | ||
The new shifter is in the car. Just got a bit more polishing to do on the knob. Not that knob. BradensEBxr6, What I have done is taken a piece of 20mm dia. 316 stainless steel round bar(solid) and turned one end down to 10mm dia. about 50mm long and cut a M10 thread on it 30mm long. On the other end of the stick, I cut up the centre of the round bar about 40mm to create a flat surface to mount to the selector and I have put a small S bend in the stick. I can't tell you how long I cut the round bar because I didn't measure that. Was a "that looks about right" thingy. I will post some pics when I've finished "knob polishing" and I work out how to use photobucket
24-10-2006, 08:58 PM | #12 | ||
Also if you make your own, you'll need to replace the two bolts at the base of the stick because the factory ones don't have a long enough thread. When you replace them, make sure they're high tensile so they don't snap. High tensile bolts usually have 8.8 stamped on the head.
25-10-2006, 12:39 PM | #13 | ||
I know a bloke who just removed his shift lever via the two bolts and cut the stick in half. Then put a thread on the end to screw the OEM knob back on. Looked good.
26-10-2006, 07:49 AM | #14 | ||||
Ea Falcon S
Jarv Smith 88' Ea Falcon S 3.9MPFI 5 speed Manual Motivator Headers with 2.1/2" RedBack system XR x GT Hybrid Body 15" 'Snowflakes' 90' GL Interior Custom Black Vinyl Roof Custom Console Lid 9" LCD + PS2 Boss CD/MP3 head unit 50x4w Quote:
26-10-2006, 07:53 AM | #15 | ||
likes falcon's
but that's just literally shorter, with the same strokes.
28-10-2006, 08:46 PM | #16 | ||
Shorter stick means shorter strokes. It all pivots from one point. The longer the stick, the longer the radius, the longer the throw.
28-10-2006, 09:49 PM | #17 | ||
rofl copter
that rubber is to stop vibration on the stick from the gearbox, its a crap load better if u take it out and run the stick solidly mounted to the box
GQ patrol.
.... thats all |
