Old 22-10-2006, 02:40 PM   #1
reded
ThUmPeR
reded's Avatar
Default EF door trims
im going to put EF door trims into my ED falcon Gli and im not sure if they will fit strait on or not???
and did the EF's come out with manual windows at the front and back because i have manual windows??
any help is apreciated.
cheers troy
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
2.5" exuast, Pacemaker extractors
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
clear indicators all round
Full EL Ghia interior
reded is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2006, 07:21 PM   #2
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
my EF I has all crank windows. dunno if theyd fit straight on. ill put some pics up tomoz 4 ya...
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2006, 07:24 PM   #3
DEVL-XR
EBII XR6
DEVL-XR's Avatar
yeh they all do except for one on the rear i think which just needs modifying to be screwed on or something.
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2006, 07:25 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
you'll need EF Gli door trims, they're the only ones that have all 4 manual winders.
not sure on whats needed to actually make em fit though, most likely something to the rod for the door handle.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 22-10-2006, 08:11 PM   #5
reded
ThUmPeR
reded's Avatar
ok thanks heaps pat.
and thanks "Braden" and "EFFalcon" im going to call the auto wreckers and ask them how much it is to buy an EF gli i saw out there so i have 2 cars
i'll use the EF for parts.
thanks for the help guys
cheers troy
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 22-10-2006, 08:14 PM   #6
efgiar
rofl copter
efgiar's Avatar
the rod needs to be "persueded" into place with a bit of bending
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2006, 08:23 PM   #7
reded
ThUmPeR
reded's Avatar
oh ok so do i need to bend it on a 90degree angle or something or just bend it to reach the latch?
cheers troy
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 22-10-2006, 08:31 PM   #8
nos_james
nos_james's Avatar
also watch the fit were the speaker grill is molderd to sute the dash
nos_james is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2006, 08:33 PM   #9
reded
ThUmPeR
reded's Avatar
yeah ok thanks ill have a good look at it all.
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 22-10-2006, 08:46 PM   #10
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
cheers troy
ummmm... y? y not just get the trims n whatever else? ie air intake box for ur pod....
EF Wagon Project:
Old 22-10-2006, 08:47 PM   #11
reded
ThUmPeR
reded's Avatar
well depending on the price... if its cheap ill get it, if not ill just get what i need.
ill prob just get the parts now i think about it.
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 22-10-2006, 10:06 PM   #12
OED666
OED666's Avatar
the only trick is the inner door handle rods. they fit perfect.!!!
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2006, 07:57 AM   #13
reded
ThUmPeR
reded's Avatar
good that means only a little bit of handy work.
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 23-10-2006, 09:03 AM   #14
DEVL-XR
EBII XR6
DEVL-XR's Avatar
i think ef/el fairmont door trims roughly cost $60 each down here in bendigo so the gli ones shouldnt be too badly priced each. wouldnt you use the handle rods from an ef?
also reded since the ef's dont have door lock buttons except the drivers door, you'll have to take off the door lock rods, easy to do. i think this is correct or is it only el's that have just one door lock button on the door trims?
DEVLXR
Old 23-10-2006, 09:45 AM   #15
OED666
OED666's Avatar
ef's have 2 door snipper buttons, el's only have one.
also for the rear, there are little brackets that are on the rear doors which the handle part of the door trims screws to. you will need those as well from the wreckers
Turbo Barra ED 4L
Old 23-10-2006, 09:52 AM   #16
dansedgli
dansedgli's Avatar
What do you do with the lock buttons that you dont need anymore? Do they work okay if you just remove the button?
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2006, 10:26 AM   #17
RUQ1KA
Formerly mad_ed_wagon
I had ef trims in my ED i just ripped off the lock buttons and had no problems with anything
The trims actually fit great and suited the car well,only thing is that rod was a ba$tard to persuade into the right shape!
Here are some pics for you
im actually considering putting EF trims in my EB aswell
you will also need this wiring diagram for the power mirrors
Hope this helps
2004 BA FALCON XT/GHIA WAGON
Build thread coming soon!
Originally Posted by RogerCordia
I had two cordias but recently i sold one of them so that leaves me with one cordia which i have now but i wouldve had two if i havent sold the other one.
RUQ1KA is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2006, 10:31 AM   #18
dansedgli
dansedgli's Avatar
They look heaps better than EA-ED ones.
That diagram should come in handy as well. Thanks for that.
Old 23-10-2006, 10:36 AM   #19
RUQ1KA
you can thank Wayne (Madnc8) for the diagram
his the one i got it of back when i was doing my conversion, without it i woulda been stuffed:P
Old 23-10-2006, 11:22 AM   #20
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
Hope this helps
You've got EF seats as well. Did you modify the floor pan?
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2006, 11:29 AM   #21
EFFalcon
Last warning
EFFalcon's Avatar
he *had* EF seats :P
he just used a spacer under the rear mount.
another bit of trivia, those were my original seats.
Old 23-10-2006, 11:41 AM   #22
XR Martin
XR Martin's Avatar
ELII has only has the drivers lock button, EFI/EFII and ELI have both driver and front passenger.
Getting rid of the front left one one is good, stops the passenger from hitting the lock when they put their elbow on the top of the door trim.
Make sure you dont get the EF trims that have the screws in the different location, they had them on the side of the trim, rather on the face of the trim like in EA-ED and EL.
2004 BA wagon RTV project.
Old 23-10-2006, 11:45 AM   #23
OED666
OED666's Avatar
here's some pics of mine...
Turbo Barra ED 4L
Old 23-10-2006, 11:49 AM   #24
dansedgli
dansedgli's Avatar
Are you using EF seats as well OED? It all matches so well.
Old 23-10-2006, 11:56 AM   #25
DEVL-XR
EBII XR6
DEVL-XR's Avatar
no there ed xr6 sports seats. the door trims have had the inserts re-trimmed to match the seats.
DEVLXR
Old 23-10-2006, 12:18 PM   #26
OED666
OED666's Avatar
ED XR8 Sprint front and rear seats... so comfy!!! I've had this interior for around 2 1/2 years now.
Turbo Barra ED 4L
Old 23-10-2006, 12:42 PM   #27
EF_Frmnt
EF_Frmnt's Avatar
you bastard. id swap ef fairmont seats for those.
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2006, 01:09 PM   #28
RUQ1KA
I had EF seats for a couple days people were recomending to make a bracket for the back but i just did a dodgy install then decided it was to dodgy so i ended up just getting rid of the seats altogether (go the sheepskin seat covers : )
this is the part that needs modifying at the rear it sits about 10cm from the floor, i do not recomend you put a tube there though thats just plain stupid, make a proper bracket for it, if i had of been in an accident during the time i had them installed it wouldnt have been pretty
here is a little comparo between ED gli and EF gli seats
it is a good conversion to do but dont take the dodgy way out, if i end up doing it to my wagon im welding the ef bracket to my floor.(or figuring out something that will last in an accident)
Once again do not copy my dodgy pipe/bracket thing!
Old 23-10-2006, 04:44 PM   #29
RUQ1KA
Originally Posted by OED666
I love that blue led behind the handle
Old 23-10-2006, 05:01 PM   #30
OED666
OED666's Avatar
You know, i get called that heaps.
yea, i like em too.. not too ricey, they are only on when the doors are open, or interior light turns on.
Turbo Barra ED 4L
