Old 22-10-2006, 02:53 PM   #1
BLDNUT01
BLDNUT01's Avatar
Default ACL race kits
hi i was wondering if these kits are any good and worth doing as i,m re building an ef motor so i can drop it in my ea cos i have seen it on ebay??
http://cgi.ebay.com.au/ACL-Race-Seri...QQcmdZViewItem
BLDNUT01 is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2006, 03:01 PM   #2
Jason[98.EL]
Jason[98.EL]'s Avatar
gday there
you should talk to trick xd as he has just used all that stuff in an el rebuild
although he has a real wicked cam with his
he killed a 4 spd auto in no time ( like a 3 hour drive from warnambool to melb )
ill message him and see if i can pass ya details to him
pm me ya mobile number
jason
[SIGPIC][/SIGPIC]
Old 22-10-2006, 06:08 PM   #3
BLDNUT01
BLDNUT01's Avatar
killin the auto sounds fun lol thanks 0433018855
Old 22-10-2006, 06:28 PM   #4
Jason[98.EL]
cool ill send him a link of this thread and he will get on to you
jason
[SIGPIC][/SIGPIC]
Old 22-10-2006, 06:36 PM   #5
MADED-6
MADED.6
MADED-6's Avatar
yeah thats the kit i am getting and i might bid on that but dont u need the size of ur bore first because thats wat it says on there website because u have to get it honed.
cheers josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2006, 08:30 PM   #6
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
cheers josh.
well yeah... 1st thing you need to do is pull your motor apart and check your bore. also what size pistons are they? 0, .5mm, 1mm oversize? also you don't know what condition your crank journals are in. they may need to be machined, so in that case you would need a certain size bearings. don't worry bout that though as bearings are about $30 for a set.
pete j
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2006, 08:34 PM   #7
EB Pete
EB Pete's Avatar
sorry just had another look at the ebay site and those pistons are 0.5mm oversize, so you will need to get your cylinders bored and honed. rod and main journals are std bearings so you will need to get your crank mearsured and machined or linished.
pete j
Old 23-10-2006, 08:49 AM   #8
BLDNUT01
BLDNUT01's Avatar
thanks got the head off already havin a great time except my back prob wait until i get the head and block checked out b4 i buy it so i know what i need
Old 23-10-2006, 03:47 PM   #9
2kool4u
Location: I live in my own little world, but it's alright, the people know me here
how much are these kits??
tafe has ebay blocked
Man who walks through plane door sideways is going to Bangkok.
2kool4u is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2006, 05:16 PM   #10
MADED-6
MADED.6
MADED-6's Avatar
well with trade discount i got quoted $750 for one i might buy this and just buy seperate bearings if i need them.
cheers josh.
TUFAU-8
Get Stroked.
Old 23-10-2006, 06:19 PM   #11
trick_xd
I build your wish list...
trick_xd's Avatar
$750 is a ok price.. I get a great deal with repco and I payed less then that..
The e-bay kit seems ok with that kit and a good cam I dont see a problem with you getting 140kws and if you get it foe say .. 300 add another 600 for cam and 200 for machine work and peice it together on a sunny sunday arvo you will have a good motor
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2006, 07:06 PM   #12
EB Pete
EB Pete's Avatar
how much did you pay trick_XD with you discount? as i also get a very neat discount.
i wouldn't bother with a rebiuld kit, as all you need are the pistons, pins and rings. the engineering place will supply the bearings and bottom end gasket set for a few $$$, and you will be wanting to use an AU head gasket.
but $250 for a full rebuild kit i would pay straight up. i payed $390 for those pistons and rings RRP is somthing like $750.
pete j
Old 23-10-2006, 08:35 PM   #13
MADED-6
MADED.6
MADED-6's Avatar
yeah alright cool. i recon the head gasket in the kit would be just as good as its a composite gasket i heard they were good. i didnt end up bidding as i need to get my sizes and then i need to order it. and im hoping for 160rwkw with that kit and dev5 cam and headwork.
cheers josh.
TUFAU-8
Get Stroked.
Old 24-10-2006, 01:33 PM   #14
trick_xd
trick_xd's Avatar
I got all this and new water pump , timeing chain , guides x3 , and new guide bolts x2 the AU h/gasket and bolts .. all that and still change from $1,200
I used BA rods they cost me $180
but you could just use your own rods .. not a lot of diffrens
machine the block 10*and open up the oil gallerys
and reco a head with new valves and seats k.lines and 20hrs on the die grinder.. That sort of my motor .. and a few other little things
But My motor is L.P.G. thats why I went hi-comp
if you are on fuel this sort of setup would require atleast 98ron all the time.. But it would be a realy good commadore killer.. With or Without a stall and diff gears and you will be spending your money on tyres if your not carefull
I have all my part numbers at work so if you need something let me know.
This is the 2nd acl kit I have used and they seem good for what you get..
Old 24-10-2006, 01:51 PM   #15
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
im liking the sound of this.... not the 98ron tho...
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2006, 06:28 PM   #16
MADED-6
MADED.6
MADED-6's Avatar
i use 98ron anyway so thats not a problem. and im using my standard rods but have sent my crank off to get balanced which i have to get my kit b4 they do that as they need the pistons and my pressure plate flywheel and harmonic balancer. i have had my head ported and i have a dev5 cam for it and am hoping for 160rwkw shouldnt be to hard as the dev5 kit gets 170rwkw.
cheers josh.
TUFAU-8
Get Stroked.
