Old 25-10-2006, 07:59 PM   #1
alecrain
'03 BA XT
alecrain's Avatar
Question door speakers
Hi guys,
I bought a futura with Pioneer stereo but no speakers.
I've put two 6' in the back and two tweeters under windscreen.
Now I want to put some in the front door but I'm not sure how to open the speaker cover, I don't want to force and break it.
Should I unscrew the whole door panel?
How big speakers can i put there 6' or 4'?
thanks
alecrain is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2006, 08:02 PM   #2
reded
ThUmPeR
reded's Avatar
yoy have to take the enite door trim off to get the the speaker, the cage is just for looks and to let sound out.
and the speakers are 6" or 5.1/2"
cheers troy
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
2.5" exuast, Pacemaker extractors
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
clear indicators all round
Full EL Ghia interior
reded is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2006, 08:28 PM   #3
alecrain
'03 BA XT
alecrain's Avatar
Default thanks reded
thanks reded,
Old 25-10-2006, 08:32 PM   #4
reded
ThUmPeR
reded's Avatar
no problem mate, have fun.
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 25-10-2006, 08:49 PM   #5
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
factory are 6" but 5.25" fit fine...
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2006, 08:52 PM   #6
Dezza
Parts bin special
Dezza's Avatar
The doortrim's easy to take off. It's only about a 2-5 minute job
Old 25-10-2006, 08:55 PM   #7
reded
ThUmPeR
reded's Avatar
hey pat were did you get the 5.25" splits from?
was it jaycar? when i went in there all he had were 6" :(
cheers troy
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 25-10-2006, 08:57 PM   #8
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Yeah 6" are the best BUT watch you dont get a 6" speaker with a deep cone as if its too deep it will hit the window when the window is wound down.
I have 6 1/2" speaker in mine which can be fitted either by cutting the holes bigger or using a 6 1/2" 6mm spacer
But watch out as cutting metal to fit bigger speakers legally makes your car unroadworthy
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2006, 09:00 PM   #9
reded
ThUmPeR
reded's Avatar
only if they know its been cut.......;)
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 25-10-2006, 09:08 PM   #10
Sorted
Sorted's Avatar
Yeah Shhhhhhhhhhhhhhhh :
Tuned by DYNOMOTIVE
Old 25-10-2006, 09:14 PM   #11
reded
ThUmPeR
reded's Avatar
if you do a good enough job they wont notice or wont care.
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 25-10-2006, 10:33 PM   #12
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
troy, autobarn. sony Xplod's. was over charged for em... i just saw em and got em... $200 for 150w splits lol!
EF Wagon Project:
Old 25-10-2006, 10:56 PM   #13
jason_85
I replaced mine in my el fairmont the other night!
I just used teh Jaycar 6" 2way speakers, $39.95 and go great. they are rated at 35rms and cause i only have my sub running of an amp they are fine cause a standard head unit output is only approx 20 - 25rms x 4.
The only issue is you will probably need a drill cause ford kindly attach there speakers at 120degree intervals (3 screws, in my EL Fairmont, not sure on others) and they use those pain the butt weird headed screws. I was careful and just used a set of pliers to unscrew and rescrew.
The $40 response speakers a world above the standard pioneer ones and go great!
Goodluck!
jason_85 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2006, 07:55 AM   #14
reded
ThUmPeR
reded's Avatar
oh ok good old impulse buying. i was in jaycar and the have 6" splits for $150 forgot what RMS they were tho...:( he said best splits there is....?
1994 ED Falcon
ICE:
7" DVD
BIG MTX sterio
OTHER:
K&N Flat pannel
20" Gianna wheels
Dropped on Pedders
BA Bonnet bulge
Old 26-10-2006, 08:11 AM   #15
jason_85
i think the 6" splits are about 75rms, they're up that way anyway. i am sure they are cheaper than $150
two of my mates have them!
value for money you cant go wrong they are awesome! I just couldnt be bothered hiding crossovers and running tweeters
Old 26-10-2006, 08:18 AM   #16
jason_85
My memory must be shot! Here are the specs!!!!!!
5" Coax 30rms - $30
6" Coax 35rms - $40
5" Coax Kevlar Cone 50rms - $110
6.5" Coax Kevlar Cone 75rms - $120
6" Kevlar Splits 55rms - $140
6.5" Kevlar Splits 60rms - $150
Old 26-10-2006, 09:49 AM   #17
tabletennisman
tabletennisman's Avatar
They're the best probably under $300. On caa (car audio australia) forums, people always recommend these Jaycar 6.5" splits along with sound deadening with a budget of $300.
And they're 60wrms.
tabletennisman is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 02:49 PM   #18
alecrain
'03 BA XT
alecrain's Avatar
Default I installed JVC 6.5"
Hi guys, thanks for your posts.
I just want to say that I put 6,5" JVC splits (were on special in supercheapauto) and they're very nice.
The good thing about them is that you can either screw them with 4 screws or 3 (most fords have 3 holes every 120 degrees).
According to my calculations the max deph of the speaker cone shoudn't be greater than 63mm, however most of the speakers I saw were between 40-46mm deep.
To put the speakers you have to unscrew door handles and the whole panel.
Thanks again
Old 27-10-2006, 04:05 PM   #19
5L
[ 5L ]
5L's Avatar
does anyone know if the alpine type r 6.5 inch splits will fit into an eb door, or will they be to big and hit the window.
www.ignitionimages.com
Old 27-10-2006, 04:14 PM   #20
SwarvJarv
Ea Falcon S
SwarvJarv's Avatar
sorry to change topic, but whats the size difference between speakers in a EA door compared to a ED door.....the ED's seem alot bigger??....
Jarv Smith
88' Ea Falcon S
3.9MPFI
5 speed Manual
Motivator Headers with 2.1/2" RedBack system
XR x GT Hybrid Body
15" 'Snowflakes'
90' GL Interior
Custom Black Vinyl Roof
Custom Console Lid
9" LCD + PS2
Boss CD/MP3 head unit 50x4w
Originally Posted by Rmyers
I was considering chucking on a full Kappa tracksuit but reconsidered :P
SwarvJarv is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 04:16 PM   #21
5L
[ 5L ]
5L's Avatar
ea is 4" ed is 6"
Old 27-10-2006, 04:17 PM   #22
Allen
You win again, gravity!!!
Allen's Avatar
EA's (and EB1 IIRC) have a 4" Speaker versus the EB2 - ED 6" speaker.
1966 Fairlane 500 XL
Allen is offline   Reply With Quote Multi-Quote with this Post
