09-12-2006, 03:26 PM | #1 | |||
Patience is a virtue
As the title says if I try to run the defrag it says
or B get rid of it so I can run defrag?? |
09-12-2006, 03:27 PM | #2 | |||
Central to all beach's
Real Aussie muscle cars have a clutch!! http://www.roadsense.com.au/about.html |
09-12-2006, 03:53 PM | #3 | ||
Its had the same message for months and never run it and as such I cant defrag and its annoying as hell
09-12-2006, 03:57 PM | #4 | ||
Dual O2 sensors
Open the command line by going to Start > Run and typing in cmd.
At the command line type Chkdsk /f. Respond Y to the question (it will ask if it can run at next boot time as the hard disk is in use). Reboot the PC and let the chkdsk run. Depending on the size of the hard drive and the amount of errors it will have it could take 15mins to 2hrs.
Black 1990 300zx Twin Turbo 5 Speed Manual : Blue 2004 Mini Cooper S 6 Speed Manual - Yes, thank you Amanda. I realise now that you updated my signature to include your car. : |
09-12-2006, 04:00 PM | #5 | ||
no worries blueraven will do it now thankyou
Will update after the V8's |
09-12-2006, 05:55 PM | #6 | ||
Well im still at a loss! Tried blueraven's idea twice now and still no go
09-12-2006, 07:12 PM | #7 | ||
Do you have a WinXP CD?........if so boot off that by changing the boot order in the BIOS and making the CD/DVD Rom drive the 1st Boot Device, save changes and reboot the PC.
At the menu option select "R" to repair a Windows Installation, the PC will then locate the Windows installation location, usually "C:\Windows" which unless you have multiple OS on your system which you probably wont, select 1. You may have to enter the password to get into the Administrator account if you have a password set up At the command prompt type chkdsk /r |
09-12-2006, 08:01 PM | #8 | ||
ok robjh80 will try it. Hopefully I wont stuff it up
09-12-2006, 08:04 PM | #9 | ||
windsor user
i once had a virus that just kept running something every 5 minutes which wouldnt let me defrag........... not very computer literate so had it repaired..was definatley something simple as the IT guy only charged 30 bucks.........
09-12-2006, 08:28 PM | #10 | ||
yeah I dunno what this is as everytime I sturt up the puter I got to uninstall the realtek drivers and reinstall just to get sound! Was gonna just reformat the damn thing but I got too much stuff I want to keep
09-12-2006, 09:48 PM | #11 | ||
You can disable automatic checks. This isn't what I recall but see if it works:
1. Run the Registry Editor(Regedt32.exe). 2. Under the HKEY_LOCAL_MACHINE subtree, go to the following subkey: \SYSTEM\CurrentControlSet\Control\Session Manager 3. Change the BootExecute entry from: autocheck autochk * /r\DosDevice\C: To: autocheck autochk * above you want to delete the autochk entry altogether. export the entry first as I'm fairly sure I've used a different method. The disk sounds like it really needs attention. |
09-12-2006, 09:52 PM | #12 | ||
The 'Stihl' Man
Im pretty sure defrag wont work unless you have atleast 50% free space, or some percentage like that. The GUI version anyway.
09-12-2006, 09:57 PM | #13 | |||
If you have any programs installed on D just delete the program's folder (way quicker than uninstalling). If any of them can't be deleted just leave them, because when you reinstall Windows, the registry will be wiped and they will know longer be known to the OS system and you can just delete them after that. That's what I did. It still took 10hrs but last time I wiped everything and it took easily double that. |
09-12-2006, 09:58 PM | #14 | |||
09-12-2006, 10:08 PM | #15 | |||
Formally Kia Chaser
type in the following:
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
09-12-2006, 10:10 PM | #16 | ||
The 'Stihl' Man
defrag is good, I always see a slight speed increase for a few days anyway
09-12-2006, 10:11 PM | #17 | ||
OK ok now you guys have complety lost me LOL
Im all confused and might just take it to the fixit guys! |
09-12-2006, 10:11 PM | #18 | |||
All Bran = Regular Member
As you've already tried various remedies, go to Start/Control Panel/Administrator Tools/Services and check that you have "Event Log" as a running service? Report back... |
09-12-2006, 10:13 PM | #19 | |||
then if it still wont defrag do /run/defrag /f it should ask if you want to go to a reboot .. I suspect you have either a virus or a sick puta , gat back to us if these suggestions dont work and good luck . |
09-12-2006, 10:14 PM | #20 | |||
09-12-2006, 10:16 PM | #21 | ||
I got pccillin with all the latest updates and after running a full scan it only warns me about cookies
09-12-2006, 10:18 PM | #22 | |||
I would tend to run with atec's suggestion and virus check for starters. edit: oh, you already have. I would consider a repair. Do you have your Windows cd? |
09-12-2006, 10:31 PM | #23 | ||
Yeah I do. Just type in what atec said in the "run" thingy in the start menu??
09-12-2006, 10:36 PM | #24 | ||
Everytime I've done a repair it's stuffed my computer more than fixed it. It's still worth a try. If all else fails, nuke the bastard
09-12-2006, 10:47 PM | #25 | ||
Doh. I just tried robjh80 idea and cant remember my administrator password :gren:
09-12-2006, 10:52 PM | #26 | |||
09-12-2006, 10:55 PM | #27 | ||
yeah I just went and gave the family limited accounts and gave myself a password so will try again
09-12-2006, 11:04 PM | #28 | |||
I would say boot in safe mode and try do a virus scan but I have PcCillin aswell and it won't work in safe mode as I have tried it. |
09-12-2006, 11:52 PM | #29 | ||
Joe, have you installed xp before? If so, you might want to consider a repair installation (as opposed to recovery console).
Have a look here http://www.microsoft.com/windowsxp/u...ps/doug92.mspx or google for similar info. |
10-12-2006, 12:23 AM | #30 | ||
Well the repair install worked and so did the chkdsk
Now Ill go try the scan disk! And the uninstall/reinstall of the realtek97 drivers seem to have been fixed so far so thankyou all so far :baby bott :1syellow1 : edit; wellwell look at that the defrag is working now. Hopefully it will get this POS runnin right now thanks to you all! |
