Old 17-04-2005, 09:16 AM   #1
NZ
NZ's Avatar
Default Upgrading stabaliser bars
I'd like to know of anyones experiences with upgrading their stabaliser bars from the factory bar to something bigger.
What size was your original bar and what did you go to? did you do front and rear? And if you got bars from another falcon what model? thanks
Old 18-04-2005, 07:36 PM   #2
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
i've done front only...
only went 1mm bigger about 28mm to 29 i think (from ea to eb 5l) and noticed the difference...
karl went from eb 5l (29) to whiteline adjustable, about $240, at hardest = 32-34mm equivalent, including nolathane bushes.... absolutely awesome improvement, worth the money IMO and something i've definately put on my to-do list...
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2005, 11:28 AM   #3
NZ
NZ's Avatar
it was actually 25.5 to 26.6
the whiteline one was 30mm
Old 18-04-2005, 07:51 PM   #4
Psycho Chicken
Psycho Chicken's Avatar
I only went up a mm or two (stock EB 4.0 to stock EF 4.0) and noticed the difference. Also whacked nolathane sway bar bushes in while I was there.
Old 18-04-2005, 07:54 PM   #5
niko
likes falcon's
niko's Avatar
how thick are ef xr ones? i was thinking of putting in my car but dont know if i can be bothered
www.carhubsales.com.au
Old 18-04-2005, 08:05 PM   #6
ilsautomotive
Former E-Series Member
I think I heard something about EF 4.0 being the same as EB XR6. I've got my EL one lying around so might as well use it.
Old 18-04-2005, 10:11 PM   #7
Psycho Chicken
That's why I put them in. They are a bee's dick smaller than XR ones I believe, but it's only a tiny bit. I think it was 2mm thicker up front and 1mm at the rear. I did it almost a year ago so I forget.
Old 18-04-2005, 08:15 PM   #8
niko
likes falcon's
niko's Avatar
wen do u notice it most, lowered car taking corners hard?
Old 18-04-2005, 09:58 PM   #9
old_mate
Smash the Boost
old_mate's Avatar
I have a 32mm whiteline in the front of my car, and its the best
Will only got XR6 spec for the rear when i come across one.
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2005, 10:32 PM   #10
stockstandard
I dont know a hell of a lot about suspension setups, but wouldnt you be having some wicked understeer with stiff front and stock back?
Originally Posted by casper
Old 18-04-2005, 10:40 PM   #11
old_mate
Smash the Boost
old_mate's Avatar
A little bit. Im also running 235 tyres at the rear with 215 up the front so that doesnt help. Its not all that bad, but would be better if i had 17's and same size tyres plus the bigger bar in the back
Im also running king lows, koni reds up front and bilsteins in the bum. And a camber kit is fitted also
1971 Fairmont Sedan
1974 SWB F100
Old 18-04-2005, 11:40 PM   #12
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
can i get this straight
EA/EB - 28mm
EB 5L - 29mm
EF/EL - ???
and also is it reccomended to get a wheel alignment after fitting a front one??
bender
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber :, EL XR8 Sway Bars, NGK Iridium Plugs, New Trip Comp, Pacemaker 4480, 2.5 system 4L ED engine with surecam
Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
EA_Bender is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2005, 11:50 PM   #13
needturbo6
ooga-lagga-ligga-lagga
needturbo6's Avatar
bender
i would say yes, i fitted one to my laser and the steering was a bit stiff, got a wheel alignment and it was better than b4 i installed the sway bar... i would at least get a check up
may be differrnt with a falcon though since the camber is non-adjustable without an aftermarket "kit", which i think are about 100 or so
needturbo6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2005, 11:55 PM   #14
Psycho Chicken
Sway bars have nothing to do with allighment. It may highlight an unalligned front end, but it won't change it.
Old 19-04-2005, 07:34 AM   #15
Spider_GT
Prince Of Darkness
Spider_GT's Avatar
El are equal to ed xr swaybars im running EL front in mine now and noticed a difference
Engine;
351 Crank, 302 Rods, Custom Pistons, Blue Print & Balanced Bottom End, Crower Stage 5 Cam (Cam Specs), , CHI 3V Heads. ENGINE PIC HERE
Body:
XD Fairmont Ghia
Spider_GT is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2005, 08:03 PM   #16
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
EB/D XR front bar was 27mm, the biggest bar up until then.
The EF/L stock front bar is 27mm.
EB/L XR rear bars where 24mm.
I am running a 30mm front bar from pedders, and a stock 24mm rear.
handles fine.
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2005, 08:29 PM   #17
mcflux
mcflux's Avatar
I must upgrade my bars!!!
Karl you're always posting what I"m thinking...
-Dave-
Last edited by mcflux; 19-04-2005 at 08:36 PM. Reason: Afterthought: removed surplus text :p
