Old 18-01-2007, 10:56 PM   #1
efgiar
rofl copter
efgiar's Avatar
Default gasket identification...
i bought a acl gasket kit and i know what most of them are but im not 100% sure on the ones in this pic.
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2007, 11:03 PM   #2
niko
likes falcon's
niko's Avatar
rubber bit sits on top of the timing case/under rocker cover
www.carhubsales.com.au
Old 18-01-2007, 11:14 PM   #3
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
The square and round ones are what you labelled them as. And the plastic is for the timing case/rover cover as niko said.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2007, 05:48 PM   #4
efgiar
rofl copter
efgiar's Avatar
what about the 3 in the center? the 2 little ones and the big one?
GQ patrol.
thats all
Old 19-01-2007, 06:23 PM   #5
XR_Lightning
Riding The Lightning
XR_Lightning's Avatar
the big one looks like the timing cover gasket, does the big one come apart? as with timing cover gaskets there are two seperate gaskets and left one and a right one, there also looks to be a thermostat gasket among the big on, and yeah your right on the water pump, throttle body and I think niko is right on the rubber one it looks like the verandah seal
ED XR6 - T5 - 1521a@112 - 3.9's - 170.2rwkw - POWERED BY METALLICA
XR_Lightning is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2007, 07:27 PM   #6
MADED-6
MADED.6
MADED-6's Avatar
yeah eb lightning is right they would be for the timing case
cheers josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2007, 09:29 PM   #7
trick_xd
I build your wish list...
trick_xd's Avatar
you have the ISC W/pump and T/B right
the rubber one sits on top of the timing cover and YOUR HEAD sits on it.
The little 1 with the 4 holes in it is a gasket for you OIL PUMP( it has 2 gaskets )
The large one you pull apart and it is a timing cover gasket. Use a bit of grease to hold it there.
there is a left and right and it allso depends what timing cover you are useing.. You might have to trim the gasket a little near the water pump.
When you put the rubber seal on fill the ends with selastic and make sure you poke the ends in tight.
and as you know a heap of E-series have a problem with oil weep from under the head/top of timing cover so if you want to run a small beed of selastic along the rubber as well. That will stop it from weeping in a few mths .
If it weren’t for physics and the law enforcement, I’d be unstoppable.
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2007, 09:45 PM   #8
efgiar
rofl copter
efgiar's Avatar
thanks mate. i should have the motor together in 2 weeks max im hoping and just need to get, w/pump, flywheel machined, get the clutch, spiggot bearing and thats about it i think
GQ patrol.
thats all
Old 19-01-2007, 11:22 PM   #9
Christiaan
Christiaan's Avatar
Is the ED ISC gasket the same as EF? Cos if so, thats not the gasket for it..
