Bodysnatcher
well i finally got my mk4 ghia back together and slammed the bonnet shut only to realise...****, i left the radiator cap off somewhere under the bonnet.
when i went to pull the cable release i think it either snapped or slipped out of its mount in the engine bay because theres no tension on it. please, somebody has to have had this problem before and i really want to get this bastard out of my garage today and on the road, so any help on a manual release or something like that is much appreciated. |
PM me if you want
any space to get your hand up behind the radiator and then push the holding pin accross, otherwise rip the grille out (not preferred)
#3 | |||
Bodysnatcher
PM me if you want
right up the top, this is from memory
it has a big pin with a spring and the pin is spear shaped at the end, the actual locking bit is just a spring loaded slide that when the spear passes past it, the slide flicks back to hold it from popping up.
Bodysnatcher
damnit, cant find any way to get my hand up in there and i dont really wanna bust up the grille. screw this, a job for another day.
a screwdriver onto pivot pin and push,takes a bit, but can be done...just get the angle right
Bodysnatcher
managed to get it open with someone pushing down on the bonnet while i pulled the cable, radiator cap was wedged under the cable and stretched it, so ill have to tighten the bastard up now.
