12-02-2007, 01:13 PM | #1 | ||
gday all,,,
has anyone run faster than 11,s on the ET street radial? |
12-02-2007, 03:48 PM | #2 | |||
AFF.com.au
12-02-2007, 05:47 PM | #3 | ||
Mick From APS Frankston ran 10.86 on them in his Blown LS1
12-02-2007, 08:17 PM | #4 | ||
thanks guys ,,,any idea what pressure there running in the tyres?
12-02-2007, 08:26 PM | #5 | ||
Have run 10.0's on them on 13 psi
12-02-2007, 09:43 PM | #6 | ||
Performance moderator
Good part with them is you don't need to change the front tyres to crossplys...
14-02-2007, 08:02 PM | #7 | ||
thanks fella,s ,,,
just got a set 275-50-15,,, they hook up well on tha street,,, keen to try em soon at the trak,hopeing to dip into the 10,s |
14-02-2007, 11:57 PM | #8 | ||
Rob Bertollachi in his XB Coupe streeter has run 9.4's on 7 cylinders on them, from memory Shane Greenberg in the XD streeter has run 9's on them too. Don't know what pressures though
15-02-2007, 06:03 AM | #9 | ||
Happy as Larry
11.4 @ 120mph 235/60/15 ET Streets.
They are magic!! |
15-02-2007, 01:12 PM | #10 | ||
11 Sec n/a barra Cortina
Bridge racing in the staes has run 7.9's on them!!
TF Cortina 11.493 @ 116.30mph Australia's Quickest NA DOHC 6 |
15-02-2007, 05:48 PM | #11 | ||
440cube Dart
Where do you buy these from.
15-02-2007, 06:00 PM | #12 | ||
Superplus
15-02-2007, 06:02 PM | #13 | ||
Solution Was Boost 4?, 6 & 8
George Haddad 10.4 in his 67 XR Falcon.
Full weight street car.
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
15-02-2007, 06:22 PM | #14 | ||
Weezland
I run 11,5 @125 on them,slicks only gained 0.3,but the engine was going off by then I think,I could never dump the clutch with them,best pressure I found at 12psi
15-02-2007, 06:38 PM | #15 | ||
416w 10.5@127mph
i ran 11.20@127mph, just couldnt get outta the whole in them. 60ft was like 1.9. put a set of full slicks and went 10.50@128. 60ft 1.4
the Fleet - 360rwk XE ESP - 314rwk G6ET - 245rwk XR GT - 205rwk '67 Stingray |
15-02-2007, 07:05 PM | #16 | ||
Thats the thing i run a manual and normaly leave the line at 6000rpm,1.54 60ft, so iam keen to see how the street et,s hookup
we are going to the trak on sat,,(nostalgia drags) see how we go, i have a set of MT 28*9*15 sliks to take just in case,,,, |
15-02-2007, 08:35 PM | #17 | |||
440cube Dart
Did he run the mickey thompsons or the m&h. |
15-02-2007, 09:30 PM | #18 | |||
Weezland
16-02-2007, 12:15 AM | #19 | |||
Powered by Ford
16-02-2007, 01:01 AM | #20 | |||
yes well there nugget we will see,,,were makeing more power now with this new engine so it going to be fun,,, the car hooked up pretty hard with the last engine combo with 26*10*15 MT sliks running 11.40,s with 6000+rpm launches,,, the caltraks and 90,10,s help alot ,,,i think it,s going to be in the tyre pressures to get the ET,s to hook up with the new combo,, |
16-02-2007, 04:34 AM | #21 | |||
Car was driven to the track and raced 100% the same way as it’s streeted. Look out he is fitting a turbo to it, time for some really big H/P.
[SIGPIC][/SIGPIC]
16-02-2007, 07:50 PM | #22 | |||
Weezland
Thats half the fun though I spose,playing around till you find what works.. |
09-03-2007, 09:13 PM | #23 | ||
there are several XR6 turbo guys running into the tens with these, HPF have 2 one runs 10.5 and the other 10.6
11.1@127.41mph 360rwkw (unopened) built bottom end with H-beam rods 400+ rwkw c9 and nos. much much much more to come soon |
10-03-2007, 06:12 PM | #24 | ||
If it aint Blown it Sucks
Keep in mind the worlds stickiest tyre, will not patch up a bad suspension setup.
if the suspension does not transfer the weight on to the tyres, then they will not grip. a softer tyre ( full slick) will help more, however it is just a patch, fixing the suspension will help the most. also you may find fixing the suspension and going back to a radial, will result in a quicker ET.
Australia's fastest 3V n/a Ghia 13.52 @ 102 mph @235 rwkw !! Now turbo 11.77 @114 mph 320 rwkw, 810 nm torque, 280rwkw @3000 rpm !! :thebirds: Now for sale http://www.fordforums.com.au/showthread.php?t=11296772 Thanks to Snort Performance, Headsex and CVE Street car DeTomaso Pantera Drag car 1995 Mustang, Haleys Comet ( It's back !) Power by CVE Melbourne's first SNIPER Tuner : Now tuning E series |
10-03-2007, 07:11 PM | #25 | |||
Weezland
12-03-2007, 12:17 PM | #26 | ||
From what I heard the conrods made an escape attempt...
30-03-2007, 01:42 AM | #27 | |||
didnt hav much luk there nugget... had traction issues with the et streets ,would not hook up to well on all the passes,, 11.01 to 11.30.s,,,122 to 125 mph fitted some slicks on the last pass of the nite,,hooked up hard,lifted the fronts up,,,1.52 60 foot,,made it to forth gear just hitt,n 6800rpm 3/4 trak and then it went and got the rods out,,,ouch : rebuilding at the mo,, '''its a real downer when ya off the street''' |
30-03-2007, 01:43 AM | #28 | |||
''that is correct there dave'' word gets around quick |
02-04-2007, 06:09 PM | #29 | |||
Weezland
02-04-2007, 06:54 PM | #30 | ||
been there done that hey nugget,,,,?
ial post some piks later of the damage,,,see who made the most damage,, ''LOL'' : |
