Old 07-03-2007, 07:30 PM   #1
Mish
Mish's Avatar
Default Efi 1600 Xflow
G'day
Just wondering if there was a possible EFI set up that could be bolted to a kent 1600 xflow??? something similair to the sierra set up but the 1600 head is back to front from the pinto.
any info would be muchly appriciated
cheers
Mish is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2007, 09:30 PM   #2
smally289
growing up is optional
smally289's Avatar
Have a look under the bonnet of a Ka, from memory the engine looked like an old 1300 crossflow with injection wacked on. Might be adaptable.
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2007, 09:52 PM   #3
RinmaxRacing
Have you thought about sizing up some individual throttle bodies from a bike? Plenty of those around and at least its something different.
RinmaxRacing is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2007, 11:41 PM   #4
Aussie_Escort
Aussie_Escort's Avatar
http://classicford.mine.nu/forum/top...?TOPIC_ID=8871
All you need is weber inlet manifold. Anywayz its all in the thread if you read it!
Aussie_Escort is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 06:00 PM   #5
Mish
Mish's Avatar
cheers for the info
that TBI set up looks the business and u can barly see that its injected
i like that idea, gives that sleeper look
Old 04-07-2007, 10:57 PM   #6
BARTV
if you have the cash you can buy twin webber side draft throttle body injector units to bolt up to the side draft manifolds but they cost a heap .i had a twin side draft webber manifold and once got 4 small throttle body injector units from a jap importer for $40 dollars each ,made adaptor plates to mount them to the webber manifold .they had a venturi diameter of 35 mm and were the hot wire type of air flow meters built in .they linked together realy easily as they had the shaft out each side .sounded like side draft webbers with a aftermarket computer,we even had coil on plug ignition but we had to drill and fit a magnet to the harmonic balancer for the ignition pick up .I wanted to put the magnet in the flywheel but there was problems trying to mount an adjustable pickup and it was easier to mount them on the front timing cover .it took a bit to make go but cost under $600 using second hand parts and with a aftermarket oxy sensor was easy to adjust with i think 6 little knobs from memory .it was a old type on dash adjustable as you drive type..haha no longer available but i did see kits advertised on line.its amazing what these old engines can do .we used a knock sensor to activate a mild water/metholated spirits injection set up .it was cheap and worked .stopped the knock and i never melted a single piston .there is lots of little tricks for poor people or people that just like to prove old throw away engines can make serious HP reliably .did you know you can fit performance gemini valves and duel valve springs to escort heads.they are much bigger than the standard GT escort 1600 valves they are only 2 mm bigger than standard valves and gemini valves are much cheaper than GT escort valves.
Old 05-07-2007, 11:03 AM   #7
fpv_escort
are the gemini vlalves the same length??? do they have to be modified at all to fit???
so are they 40mm inlets and 34mm exhuast???
fpv_escort is offline   Reply With Quote Multi-Quote with this Post
