Closed Thread
Old 27-03-2007, 01:43 PM   #1
csv8
csv8's Avatar
Default This Porsche Really HAMMERS !!!
Features
• Design meets indestructibility: A perfect rotary hammer.
• Reduced to its key functions: hammer drilling in stone, chiseling, drilling in wood and metal, screwing.
• With a housing of aluminium and carbon plus revolutionary ergonomics.
• Developed as a result of the cooperation between Porsche Design and Metabo, the P΄7911 is the ideal combination of aesthetics and uncompromising quality because it not only shines on the outside: its inner life consists of robust engineering for the toughest demands.
Areas of Application
• Precise, powerful, fast and able to face every challenge easily: the P΄7911.
• A multihammer that covers all key functions of a drill and a pneumatic hammer: hammer drilling in stone, chiseling, drilling in wood and metal, and screwdriving.
• When drilling without impact in wood the P΄7911’s high torque ensures clean results.
• A case for loads of strength and robust engineering: hammer drilling in concrete.
• The perfect way to renovate: due to its strength and its outstanding ergonomics, with the P΄7911 tiles can be chiseled away quickly, cleanly and without the user getting tired.
• You can’t drill more safely than this: the Metabo S-automatic safety clutch limits the jerky reverse torque that can occur when the tool gets jammed during drilling.
Specifications
• Diameter drilled in:
- Concrete with hammer bits: 20 mm
- Steel (1st/2nd Gear): 10 mm/6 mm
- Softwood (1st/2nd Gear): 20 mm/14 mm
• No-load speed (1st/2nd Gear): 0 – 1.000 /0 – 2.800 /min
• Single-blow energy: 2,0 J
• Rated input power: 705 W
• Weight: 3,2 kg [without mains lead]
• Torque (1st/2nd Gear): 15 Nm/6 Nm
• Max. impact rate: 4.600/min
• Bit retainer: SDS Plus
csv8 is offline
Old 27-03-2007, 05:00 PM   #2
XR8putts
XR8putts's Avatar
Crikey the mods are slow today..
XR8putts is offline
Old 27-03-2007, 05:05 PM   #3
kenz
BOSS Pilot
kenz's Avatar
I want one :P Would look good on the jobsite
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline
Old 27-03-2007, 05:44 PM   #4
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
Being a Tradesman i better put the hammer down on this one.
Falcon Coupe is online now
Old 27-03-2007, 05:46 PM   #5
Casper
Contributing Member
Casper's Avatar
I'm Too late, Falcon Coupes already "hammered" this thread! :
Older, wiser, poorer.
Casper is offline
Closed Thread
