05-05-2005, 06:37 PM | #1 | ||
Low and Loud
I just put a new steeringrack on my EA and really need to ajust the tierod ends so the wheels are straight and not in a V shape if you look at it from the front.
I just want to get it roughly straight so i can get an alignment, atm when you try to drive you go allover the road and the steeringwheel goes crazy like something from Daytona USA : help?
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
05-05-2005, 06:39 PM | #2 | ||
I told you less than an hour ago! Undo the lock nuts, wind the tie rod out, tighten the lock nuts.
05-05-2005, 06:42 PM | #3 | ||
Low and Loud
LOL @ Rob
Do i HAVE to take the tierod end off the disc arm? i havent seen them do that at the tire places or Do you simply turn that arm (Is that the tie rod?)
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : Last edited by InitialD; 05-05-2005 at 06:44 PM. |
05-05-2005, 06:42 PM | #4 | ||
likes falcon's
ye listen to him man, sheesh
www.carhubsales.com.au |
05-05-2005, 06:48 PM | #5 | ||
Low and Loud
If you wanna come do it rob, there is a cash insentive ;)
05-05-2005, 07:05 PM | #6 | ||
undo the lock nut and the whole steering arm spins. even moses would have noticed that
05-05-2005, 07:16 PM | #7 | ||
haha, even I was able to adjust mine enough to get it to a wheel allignment joint(my dodgey mechanic). Haha. Do it on Ramps, makes it easier and keeps the wheels strait, if you havn't allready done it.
How did you find the K-Frame bolts ? mine were a bastard, get one in then the other wouldn't line up, though i think my K-Frame was slightly bent. :S Damo |
05-05-2005, 07:41 PM | #8 | ||||
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
05-05-2005, 07:49 PM | #9 | ||
FFS Mick you lazy *****!
Jack the car up, get your **** under it and do it! You don't need to take the tie rod end out of anything. You undo one nut and turn the tie rod (you know, the thing that's attached the ends of the steering rack and has tie rod ENDS on the ends?). Then tighten the thing up and go to Bob Jane's or something. Jesus you changed the rack today, unless you've changed the rod ends with it as well the lock nuts should be loose anyway. |
05-05-2005, 10:27 PM | #10 | ||
Low and Loud
Its all fine now ;)
The Steering rack was fitted with the tierodends attached as its out of Swoopa's old SVO. I ajusted them so they are roughly straight now THANKS everyone as after i posted in here last, I just thought "Bugger it ill go find out" and yea its easier on this rack then my old one. Damo - Kframe bolts were easy as I recently changed my motor and cleaned the Kframe. The onlything ive noticed is with this new rack in, the steering is very soft, like 5 times softer then before. Is this normal?
06-05-2005, 03:53 PM | #11 | ||
Low and Loud
My next question is...
I just had a wheel alignment done and im told my "Z Bar Bush's" are gone, The guy there said that the Kit for the front bush's cost $50 for the kit. Is it possible that I could install these? Or Is Pedders the best option
