Old 29-04-2007, 11:21 PM   #1
krisisdog
krisisdog's Avatar
Default ABS - Do I have it?
So how do I tell if I have ABS?
Car is as sig says - I think its a August build, dunno if that helps though.
Is there anything on the plates that would say if it does?
Is the control unit thingo in the bumper on EFs? Should I just look there?
krisisdog is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2007, 11:36 PM   #2
private9
www.TUFFCARPARTS.com
private9's Avatar
Futura's have it standard. The ABS module is located in the front left corner of the engine bay or under the front left guard, can't quite remember.
Easy way to test though is to find a safe place and jump on the brakes - you'll soon know whether it has ABS or not!
Old 29-04-2007, 11:46 PM   #3
krisisdog
krisisdog's Avatar
Thanks champ
I thought so, just wanted to make sure.
Also, does it matter about ABS and non ABS rotors? I've seen a few advertised that supposedly fit both.
Those X-drilled and slotted gold DBA rotors look mighty nice....
Old 30-04-2007, 01:32 PM   #4
ed ant
ed ant's Avatar
Default abs
my abs is under the left side or front bumper ed and el is under the bonnet
black ed lowerd king springs 16" mags pioneer sound system. :
ed ant is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2007, 04:21 PM   #5
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
The difference between ABS and non ABS rotors is only the sensor wheel on the inside of the rotor for the ABS sensor to work out how fast the wheels spinning.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 03:05 PM   #6
alecrain
'03 BA XT
alecrain's Avatar
Default wait for the rain
why don't you wait for a rainy day and test it your self. You'll know if you have it or not and if it works or not.
Find a safe spot, go 50km/h and try braking heavily. You should feel it work.
It's a good way to learn what to expect and how the car behaves, try steering while breaking etc.
Good luck and BE SAFE
alecrain is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 05:36 PM   #7
rmack
rmack's Avatar
Why don't you turn the key and see if the ABS light comes up on the dash?
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 07:41 PM   #8
ef_classic
ef_classic's Avatar
EF-EL ABS "module" is in the front left wheel "shroud".
ef_classic is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 07:46 PM   #9
Hybrid34
|AFordEd|
PUt your car half on gravel half on the road and slam on the breaks, should stop dead straight with abs ;),
orrr, if you look on the RHS of the engine bay near the airbox, on the body of the car is a round black rubber screw thing, thats your abs pump...
1996 Ford Fairlane mock by tickford
EF Xr6 Engine
EF Xr6 ECU
3:4:5 LSD diff
JMM Extractors
2.5" Stainless Steel highflow cat
2.5" Exhaust
T5 transmission
Front Slotted rotors
Lowered on Pedders Sports Ryders
....and a cherry scented airfreshner
Speed determines how fast you hit the Traffic Light....Power determines how far you take it with you.
Hybrid34 is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2007, 07:48 PM   #10
b2tf
not here much anymore
b2tf's Avatar
Futura's came standard with ABS
2024 F150 XLT
Old 07-05-2007, 02:15 PM   #11
james22
With da Warlords
james22's Avatar
Hahaha, too bad if you didn't have ABS, you'd be paddock bashing before you knew it lol :
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 07-05-2007, 02:29 PM   #12
RG
Back to Le Frenchy
RG's Avatar
Probably the quickest and easiest way of finding out.
Old 07-05-2007, 07:22 PM   #13
Gohan
funny thing bout ABS i locked my brakes up and mine is a Fairmont and thats on a wet road in the city not on tram tracks
Driven Lan Evo 9, Ex Cop AWD Magna, Ralliart Colt
Normal Driver Smashed UP! and GONE!
Gohan is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2007, 07:26 PM   #14
XR8 Uterous
Isnt there a sticker on one of the windows?
XR8 Uterous is offline   Reply With Quote Multi-Quote with this Post
