Old 11-05-2005, 12:40 AM   #1
InitialD
Low and Loud
InitialD's Avatar
Default Another (yes another) EA problemo
Hey all,
Yes again there is a EA issue (SHould have a separate "MY SCREWY EA PROBS" section for us ea ownerd ;) lol)
Ive noticed over the last 4 days that in the morning when i go to start my EA, it coughs, splutters idles VERY ROUGH and stinks of fuel, I have to hold the revs @ 2000rpm for about 10sec or so for it to clear itself out or it simply goes to stall... any thoughts? Ive also noticed that the average has gone up to 17.0 from 14.2 :yeees: Nothing has been changed or swapped over on the motor.
Old 11-05-2005, 12:47 AM   #2
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
stupid question.. how long since the oil has been dropped?
cheers,
santo
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2005, 12:49 AM   #3
InitialD
Low and Loud
InitialD's Avatar
Wha? you mean how long since ive done a oil change santo? I did a oil change on it about 2000ks ago or so i think? just after the motor had done its first 1000ks
Old 11-05-2005, 01:39 AM   #4
Panda
XR6 and XR8 Club of QLD
Check all of the obvious things
- spark plugs / leads
- did the problem start just after you refueled (dodgy batch of fuel)
- any hoses come off under the bonnet
Sounds pretty tricky, but things like this usually end up being a simple little fault.
Panda
Car - Ford Falcon XR6 Turbo
Panda is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2005, 06:01 AM   #5
bindi
Redhead extraordinaire...
bindi's Avatar
It's gotta be some fuel issue, especially if you can smell it and your consumption is up.
Bloody EA's hey... just as I try to fix one thing on ours, another two things go wrong. The thing is, now the "problems" list is overtaking the "non-problems" list :(
I'm moving to Melbourne :nutsycuck
Bindi
88 EA- his car
88 Rolla - MY car
Originally Posted by big_waity
Oh, and another surefire symptom will be the Falcon badge at the back.
bindi is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2005, 08:40 AM   #6
spope
spope's Avatar
And it runs ok after your initial start up? It'll be your TPS, no question - mines doing the exact same thing, I just haven't got around to fixing it.
Hot tip from my ex ford mechanic mate - elongate the holes for the screws, and twist the tps around a bit until it stops doing it. Problem being that the car is thinking the throttle is open more than it is and therefore throwing in excess fuel.
spope is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2005, 11:41 AM   #7
ned
Once shy... twice bitten
ned's Avatar
My TPS must be knackered too then, any idea how much one costs? Or should I just get one from the wreckers?
The Devil crept into heaven... God overslept on the 7th... the New World Order was born on September 11.
ned is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2005, 12:29 PM   #8
InitialD
Low and Loud
InitialD's Avatar
TPS eh? That actually would make sence!!!
Im having a problem atm when it goes to change gear, the auto hold gears occasionally.
Right off to get another TPS and turf the old one
Old 11-05-2005, 12:29 PM   #9
Walkinshaw
Two > One
Walkinshaw's Avatar
Sounds like a cold start problem, linked with overfuling.
Im saying its a combination of screwed temp sender and ICS.
Old 11-05-2005, 12:31 PM   #10
niko
likes falcon's
niko's Avatar
mine does it every now and then like once every few weeks, were it just runs like a reall dog, but doesnt stall
it doesnt happen often enough for me to worry bout it
www.carhubsales.com.au
Old 11-05-2005, 12:32 PM   #11
niko
likes falcon's
niko's Avatar
oh and only ever happens wen its cold, so i drive easy as to not make matters worse and it goes away within a minute or so
Old 11-05-2005, 01:08 PM   #12
InitialD
Low and Loud
InitialD's Avatar
Could someone tell me if EL's had the same TPS as a EB?
Old 11-05-2005, 01:48 PM   #13
Walkinshaw
Two > One
Walkinshaw's Avatar
I believe they are diffrent.
Old 11-05-2005, 02:01 PM   #14
ilsautomotive
Former E-Series Member
I think you can use even an AU one if you want. That's what I'd do.
Old 11-05-2005, 02:09 PM   #15
NZ
NZ's Avatar
you'd need the dual type mick. the el will be a single one. your saying the auto playing up too would be weird if both your tps are bung one for eec one for tranny.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
Old 11-05-2005, 02:47 PM   #16
InitialD
Low and Loud
InitialD's Avatar
karl, I actually have a 91DA (eb2/ED) throttle body on my car ;)
Got another 2 TPS's to try out so see what happens
Old 11-05-2005, 03:10 PM   #17
ned
ned's Avatar
How much for the TPS ?
Old 11-05-2005, 03:11 PM   #18
EA2BA
PM me if you want
EA2BA's Avatar
You can run just a single TPS if you want, tap the wires together, I have a single TPS in my conversion to 4 speed auto, and am having no problems.
Old 11-05-2005, 05:29 PM   #19
Curtis
you will find your injectors are leaking overnight and it is getting huge amounts of fuel on the valves and in the cylinders.
Old 11-05-2005, 05:34 PM   #20
InitialD
Low and Loud
InitialD's Avatar
Heres the update...
I took the Throttle body off, cleaned it out, put another TPS on and checked the ISC. Put it all back on, and its still doing it. When you go to start it, its rough as guts, like its missing, then clears itself after you rev it a couple of times.
The other interesting thing is I switched the Trip Computer to INSTANT FUEL USAGE
and when i take off normally to 60kph, and doing around 2000rpm, the instant shows 99??? None of my mates cars do this, nor does my mums EA ghia.
This sounds like my injectors are flogged right?
BTW curtis, sounds about right
Old 11-05-2005, 06:09 PM   #21
NZ
NZ's Avatar
so your running an ea computer and only 1 tps mick? have you done what jase has done?
ps your trip computer won't show the fuel going in if your injectors are stuffed. it will only show what the computer is thinking it is injecting. if its showing 99 somethings not right. usually they will show 99 if your at wide open throttle at that speed. you could get it to show 99 at 2000rpm but you'd need to have an iron foot™
Old 11-05-2005, 10:09 PM   #22
InitialD
Low and Loud
InitialD's Avatar
Yep karl, ive done the same as Jase did.....
LOL it shows 99 when i take off no matter how slow or quick
Also... Whats a set of Reco Injectors worth anyway?
Old 11-05-2005, 11:27 PM   #23
trueblue
01 Falcon Ute
i had a similar problem, i was told by a mechanic reco injectors cost 180, and brand new injectors are worth $220...
AUII FALCON UTE 2001
WTD mags to suit AU Falcon ute, AU XR rims or BA 18" xr rims. PM ME
trueblue is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2005, 11:40 PM   #24
Sundeep
Sundeep's Avatar
Injectors would be the G-O. I was thinking exactly what Curtis posted.
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2005, 07:58 PM   #25
InitialD
Low and Loud
InitialD's Avatar
Just an Update...
I tried another set of injectors in the car and it appears to have Sorted itself now!
BUT.....
Im having a old problem crop up again. The car randomly goes to stall when your at the lights? like the ISC isnt working. Now ive tried many ISC's, TPS's, etc and have had no luck, Whats the chances its my ECU thats playing up? As its the only thing i havent swapped over
Old 12-05-2005, 11:43 PM   #26
ned
ned's Avatar
Damn, that means I gotta find some money for new injectors :(
Did it fix your fuel consumption reading on your trip computer?
Old 13-05-2005, 02:28 AM   #27
chrisbee9494
Default .99
undefined
Hi, my TC shows the dreaded 99 but everything else is normal. Fuel consumption is high but the car runs well. Why the 99? cheers Chris.
chrisbee9494 is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2005, 07:29 PM   #28
kiwiman
Thumbs up
Just an Update...
BUT.....
Don't do that yet! I have been having the same problems as you and i have found that i had a faulty ecu relay. I would check that out first before you do any thing else. cheers _2:
Old 31-05-2005, 09:32 PM   #29
jjj
jjj's Avatar
Yeah mate, check the fuel pump relay and the ecu relay underneath the coolant tank behind the battery. Look directly under the 4 relays. Headlamps, starter etc. Fuel pump is green cover and the ECU is the other one. Check for corrosion on the plugs.
Cheers Luke.
EL FAIRMONT
Pacemaker 4499's
Megaflow 2.5in Cat
X-Force 2.5in Sports Exhaust
Champion STEEL igntion leads
K&N panel filter, EL GT Snorkel, modified airbox
16in Speedy Holotype-R mags on 225 tyres
jjj is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2005, 09:55 PM   #30
InitialD
Low and Loud
InitialD's Avatar
Who this is a old thread...
The problem turned out to be dodgy injectors as one of them were leaking. But my Fuel relay was screwy aswell.
My only issue now is its still like 16.5 average?? The only thing i havent changed is O2 sensor and spark plugs
