Old 07-11-2007, 09:38 PM   #1
chrispie123
Default oxygen signal wire
on my series 2 au i am hooking up the gas on it got all the wiring sorted bar the signal wire for oxygen sensor there is 3 of them there which one do i top into there is only 2 wires to go to it
chrispie123 is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2007, 12:12 AM   #2
JC
JC's Avatar
You should hook into the wires at the ECU. I've previously posted up which wires were which, but can't remember what the actual thread was about - I'll see if I can find it anyway and get back to you. I assume it's a 6? Actually, IIRC, it doesn't matter, as I posted up the wires for I6 and V8, so if I can find it, you should be in business.
Ford Performance Club ACT
Old 08-11-2007, 12:20 AM   #3
JC
JC's Avatar
Found it:
ECU wiring is here:
http://www.fordforums.com.au/vbporta...article&id=168
It has the ECU pinouts for both the 6 & the V8.
O2 sensor wire for the 6 is #35 for the live side, and #4 for earth.
O2 sensor wires for the V8 are #35 & #4 for sensor 1, and #61 (power) & #23 (earth) for sensor 2.
Old 08-11-2007, 08:27 PM   #4
chrispie123
ok in the previous car in which the gas was installed it was into the engine pay at oxygen sensor, would prefer to do it that way again easier for me which wires would it be color and stripe etc
Old 08-11-2007, 09:02 PM   #5
FGII-XR6
FGII-XR6's Avatar
the less wires you tap in the engine bay the better better in the dry enviroment of the cabin
Old 08-11-2007, 09:50 PM   #6
chrispie123
also which pin to cut out injector power
Old 09-11-2007, 01:31 AM   #7
JC
JC's Avatar
Have you checked the link I posted up? It should give all the info you require.
Old 09-11-2007, 07:46 AM   #8
chrispie123
yeh checked the link but it gave 6 wires for injectors
Old 09-11-2007, 09:36 PM   #9
chrispie123
so just needing to know which pin number needs to be relayed to stop it from running on petrol, do i just do the fuel pump and leave the injectors, or injectors and leave fuel pump running
Old 09-11-2007, 10:38 PM   #10
chrispie123
thankyou for your help jc i nutted it all out just then all wiring is complete now to mount the convertor and tank and let someone hook up the lines to get signed off
