Walking with God
What are the diff ratios for AUs?
Is the wagon and sedan different? I'm assuming yes, and I would doubly assume yes again for ute diff ratios. However, as has been the case many times before, assumptions can be based upon anything but reality! LOL! Can someone please list the ratios for each sedan wagon and ute and also a list of all available ratios? I will need to replace the diff in the sedan soon, and wouldn't mind a better ratio. BTW, I did do a search and didn't get any definitive answers. Cheers, GK
2009 Mondeo Zetec TDCi - Moondust Silver 2015 Kia Sorento Platinum - Snow White Pearl 2001 Ducati Monster 900Sie - Red Now gone! 1999 AU1 Futura Wagon - Sparkling Burgundy On LPG Want a Full Life? John 10:10 Last edited by GK; 09-11-2007 at 10:48 AM. |
From what I know George, your wagon should have a 3.23 open diff, and the sedan a 3.08 open.
Also, if you were to get a new diff, the factory LSD is a 3.45 ratio. Evan |
Walking with God
Thanks Evan, I just want something a bit lower than what I've got. I'm not going the LSD, but might hunt around for a wagon item. If the ute is lower again, I might go for one of those.
I'd still like a list of available ratios and what was on each AU though. AFAIK no one has put one together yet. It'd be a handy resource I'd reckon. GK
I dont think anyone has put a list together because, as far as i know, there is only three ratios available in the entire AU series, ute, sedan and wagon. 3.08, 3.23 and 3.45 LSD. Anything lower would be after market i think.
Evan |
Sly like a G6
All wagons are 3.23... not sure about utes, would guess at 3.23 as well. Sedans varied, AFAIK Forte & Futura had 3.08, Fairmonts 3.23 due to extra fruit. XR6's had 3.45's and IIRC so did Fairmont Ghias. Those are your choices if you want to pick one up from a wrecker, but you can get any ratio available in either open or LSD if none of those suit. I saw an XR 3.45 diff centre advertised recently, I think it was $200 or $300, may have been in the current "Just Parts".
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
Walking with God
Cheers Sly!
GK
14.915 @ 151 KPH
hi, you can also go 3.7, 3.9 or 4.1 if you want.
:evil3: 96 EF2 Futura I6 Auto :evil3: EL XR Front, 16 inch Tickford's, Superlow's Front/Rear with Monroe GT Sport's ![]() ![]() ![]() |
Narooma blue XR8 ute
how do the 3.7 or3.9 effect fuel economy
#9 | |||
14.915 @ 151 KPH
since your is an XR it has a 3.45 standard, so you probly wouldnt get much gain out of a 3.7 (yes there will be some but if you go 3.9/4.1 you will have a much better takeoff) unless yours is manual the 3.9/4.1 is way to low
Great calculator but it doesn't realy tell me much about the fuel economy side of things
depends on what sort of driving you do, on the high way you'll notice the differance, but around town you wont
#12 | |||
www.TUFFCARPARTS.com
My wagon has a factory LSD, so would this be a 3.23 or 3.45?
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
_Oo===oO_
Factory Diff ratios:
3.08 SS: I6 Auto Sedans 3.23 SS: Wagons, Manual I6 Sedans, V8 Sedans and Utes or 3.45 SS: Late Edition AUII XR6 HP, AUIII XR6 HP Sedan (unless otherwise optioned) and IRS Sedans 3.45 LSD: All AUI XR6 HP Sedans and early build AUII XR6 HP (Pre May '01 builds) sedans, all XR utes, all XR IRS Sedans, All T Series, utes with one tonner suspension option. As far as I know, any factory fitted LSD is 3.45 ratio.
#14 | |||
Sly like a G6
Is your info from a workshop manual, specs website or similar? Sometimes even the supposed experts have incomplete info. I've had a running battle with NRMA over the spec of my Smartshield update series 1. They cannot be told that later s1 cars had the immobiliser and front power windows stock from the factory, they have to be counted as "accessories" which reduces the value of mods I can make to the car before they won't insure it. Apparently Ford never officially informed them of the change in equipment levels...
#15 | |||
If the diff has a tag with the ratio on it, I might get under there today to confirm!
#16 | ||
14.915 @ 151 KPH
PRIVATE9: if you have a 3.45 1st gear should rev out @ 78-80ks and not 88ks like a 3.08
#17 | |||
14.915 @ 151 KPH
#18 | ||
Just slidin'
The Au1 Fairmont runs the 3.08 diff gears as well, its the ghia that has the 3.23's.
MD Mondeo - For the family
#19 | |||
Smile
4:11 ratio does affect fuel economy.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#20 | ||||||
_Oo===oO_
Firstly Stav, I heard and then saw your blue wagon eastbound on the M4 coming up in the left lane on Thursday. It is the loudest six cylinder AU Falcon I have ever heard.
Ok, back on topic. Quote:
#21 | ||
Just a question a little off topic, in a AUII XR8 220, is the LSD a clutch pack type or a cone type?
2008 FG GT 315 EGO #460 1968 Falcon Sports Coupe **2012 PCOTY winner** https://www.fordforums.com.au/showthread.php?t=11325000 1990 XF Falcon Panelvan |
#22 | |||
