Old 23-01-2008, 01:35 PM   #1
jamescoco1
Default Injector prob!
Hey all,
Need some help please yesterday i changed my injectors on my series 1 au ute.
since the injector change i have lost all power on both gas and petrol! when the car is cold it wont move if i let it run and warm up i can cruise if i dont accelerate past 2000rpm if i do it makes spitting sound and cuts all power....
the car is also blowing black smoke HELP PLEASE!!!!!
jamescoco1 is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2008, 02:47 PM   #2
StealthAu
Sounds like you have disconnected a vacuum hose
Old 23-01-2008, 07:26 PM   #3
HLC
Audi S3
moved to proper section
Old 23-01-2008, 10:27 PM   #4
rob_liss_lms10
rob_liss_lms10's Avatar
must be the day for it, I also changed mine today for BF typhoon ones, I ran a bit of black smoke but cleared after 5 minutes.As stockoau said, check you didn't leave of the vac hose to the fuel reg.
Red bull gives you wings?: nahhh.... we got our wings from TICKFORD
rob_liss_lms10 is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2008, 10:36 PM   #5
StealthAu
So did you need to get your car tuned to run the bigger injectors? if not is it runnig well with them?
Old 23-01-2008, 11:44 PM   #6
rob_liss_lms10
It appears to be running good,smelt rich at 1st but after 5 mins came good. I disconnected the batt when doing the change which always makes it run funny at 1st. I'm getting a new cat,muffler and exhaust shortly, so will get a retune done then.Power wise it doesn't feel any different, but I guess the computer/haltech is programmed to give only a certain amount of fuel so I suppose bigger injectors won't change much.They were for when I get my engine done later in the year,but I'm on hols and got bored.lol
Old 24-01-2008, 12:02 PM   #7
jamescoco1
ey guys!
my vac hoses there is one right in front of me at the top of the motor and another at the top back of the motor that are both connected.... but i have fount a small black plastic hose under the air filter box dangling with some sort of valve on the end that says vapours on the side of it..... but i have not touched anything near there and have no idea to what it does or were it goes.....
i am so over it i just want to sell the thing nad get an xr6T
Old 24-01-2008, 12:34 PM   #8
StealthAu
Sorry mate, but seeing as you said it is runnig poorly on lpg as well, I can't see it being anything other then a disconected vacuum hose. Maybe someone else will have some ideas
Old 24-01-2008, 02:27 PM   #9
jamescoco1
ok cool i will have to serch for these vacuum hoses and hopefully ill find the prob thankyou for your help
Old 24-01-2008, 03:01 PM   #10
jamescoco1
has anyone used the website (ford.justanswer.com) just a bit query about paying for information!!!!!
Old 24-01-2008, 05:22 PM   #11
rob_liss_lms10
if it was running ok before you changed the injectors, then it could only be something you dissconnected /bumped loose or possibly the injectors you put in were faulty/dirty.did you clean with injector spray before you put them in?Double check all of the connectors are pushed home on the injectors. If the reason you changed the injectors was to fix the problem you are now having, then I would assume that the injectors were not your problem. The hose you found is not from the top front of the tappet cover is it?
Old 24-01-2008, 05:52 PM   #12
StealthAu
As I said earlier, I can't see it being the injectors if it is also runnig crap on lpg
Old 24-01-2008, 06:00 PM   #13
rob_liss_lms10
I don't know how lpg works, I just thought it ran through the injectors as well. I will have to do a search to see how lpg works as I'm curious now.lol
Old 24-01-2008, 10:43 PM   #14
bodes-sh
just a thought, you didn't leave the vac hose off the fuel pressure reg did you?
Old 25-01-2008, 02:02 PM   #15
jamescoco1
hey guys...
No i never used injector cleaner first.. but the injectors i used were good!! the hose i found was not from the top of the tappet cover.
there is no way i left the fuel reg vac hose d/c either... i changed the injectors because i had this problem with petrol only i now have it with gas too!
I was so sick of this yesterday i decided too just drive it to a mechanic but on the way the car failed i now cant accelerate on gas or petrol the car is in a side street and will only roll in drive!!!!!!
is it possible that this could be a prob with my CAT ? or even my tranny ? other than being a vac hose.... and i am still trying to get from a friend who works behind the scenes at ford a diagram of all my vac hoses.....
Thankyou once again for your help ppl
Old 25-01-2008, 07:46 PM   #16
bodes-sh
how does it run? i know you can't drive it, but when you put your foot down does it rev up? does it idle properly? also, while it's running can you hear any sucking/hissing sound from the engine that sounds like a vacuum leak? It might be worth trying an ecu reset, just unplug the battery for a while, then do the relearn procedure and see what happens
