Old 25-11-2008, 08:53 PM   #1
Swedishmoose
Default thermal problems
Hi there,
I was wondering about the temperature gage of my 2000 Dalcon Futura. It never reaches the normal operational temperature. The gage should stand in the middle , right ?
Not even on hot days it moves near the middle . It just moves at most a quarter . If I turn on the heater on colder days it doesn't even move a quarter .
What could be the problem ?
gage / instrument ?
thermostat ?
radiator?
temperature sensor ?
any ideas ?
thanks
Swedishmoose
Swedishmoose is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2008, 09:09 PM   #2
bodes-sh
might be worth a search as this has been covered many times before...
mine sits right between the n and o of normal all the time, as do quite a few others. if you're worried get the thermostat replaced and the coolant replaced, then you will know it is all new.
Old 25-11-2008, 10:50 PM   #3
Mechan1k
Mechan1k's Avatar
Mine used to sit on the right side of the O ... but that's an EGAS model.
The first thing to replace is the thermostat ... it's cheap and worth doing anyway for starters.
Old 26-11-2008, 09:29 AM   #4
whiskers
gone fishing
whiskers's Avatar
mine has sat on the "N" or close enough to it since I bought the car back in 99 new.
as like most others here that seems to be the normal place and temp, I would worry if it crept up and didn't come back down again.
Whiskers
whiskers is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2008, 10:37 AM   #5
mik
mik's Avatar
if someone had the car before you they might have put a cooler thermostat in it, or removed it completely, but if it warms to its operating temp quickly the first option would be more likely imo.
