Old 01-12-2008, 11:39 AM   #1
blueoval
Critical Thinker
blueoval's Avatar
Default diff carrier bearing on way out
Well I just got a message from my mechanic mate who said the carrier bearing on my diff is on the way out.
Tends to whine and vibrate a little at 65kph. Common issue on the AU's apparently.
So I was thinking, while Im getting the bearing replaced, is it worth me converting to LSD and sticking a 3.45 ratio in it, or something else?
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2008, 11:51 AM   #2
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice.
Your probably be better off just replacing the whole diff with an 3.45lsd out of another car, this is what i have done, it cost me $500 for a complete S2 XR8 LSD irs assemble, yours would be a lot cheaper being non IRS. But basically to buy diff gears 2nd hand $200, to get a good LSD diff centre your looking at $300.
Are the E series live axle diff's the same size as AU, if so that would mean you would get a diff a lot cheaper.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2008, 11:55 AM   #3
blueoval
Critical Thinker
blueoval's Avatar
Thanks mate, thats what I was thinking. Might ring a few wreckers and see what they have in the way of 2nd hand 3.45 LSD centres. But what about the carrier bearing? Does that need to be pressed out and replaced or will the second hand one be ok?
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 01-12-2008, 11:58 AM   #4
5.0 ED
5.0 ED's Avatar
The 3.45 lsd diff has a large carrier bearing in it, and i have never heard any problems with them.
Old 01-12-2008, 12:05 PM   #5
blueoval
Critical Thinker
blueoval's Avatar
It sounds like they are a stronger unit. Whats the word on the bearing wearing out on a unit like this? Would I better off replacing the carrier bearing for peace of mind?
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 01-12-2008, 04:54 PM   #6
mik
mik's Avatar
i would bear in mind that in a second hand lsd at 100000 k`s the it will probably be close to single wheeler due to wear and tear, i tested mine at about a hundred thousand k`s and it had very little lsd effect, the car has never been to drags or had any abuse, if your buying a diff second hand for a lsd on its own unless its recoed i think your wasting your dough imo unless its super low k`s.
Old 01-12-2008, 04:56 PM   #7
blueoval
Critical Thinker
blueoval's Avatar
good points mik. What do you suggest then?
Get a 2nd hand unit rebuilt or by new?
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 02-12-2008, 12:52 AM   #8
5.0 ED
5.0 ED's Avatar
i've purchased plenty of lsd and had plenty of cars with them at 300,000km's and i have never got one stuff, which has been good luck, the whole thing is you have to check the diff your buying, check how much touque it takes to break the lsd and play etc.
Old 02-12-2008, 09:48 AM   #9
blueoval
Critical Thinker
blueoval's Avatar
thanks mate, will do.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 02-12-2008, 09:07 PM   #10
mik
mik's Avatar
some good advice from 5.0whiteaughia, allthough i have to admit i`m a bit partial to reco stuff, i have been dissapointed a few times over the years from buying second hand stuff over the year`s, good luck.
Old 02-12-2008, 09:21 PM   #11
blueoval
Critical Thinker
blueoval's Avatar
Thanks mik. I'm pretty cautious also. It will be interesting to see whats out there. If I have to buy new, I will but prefer not to if I can avoid it.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 03-12-2008, 12:53 AM   #12
5.0 ED
5.0 ED's Avatar
Yeah new is always nice, but with the price variance between new/reco diff centre and gears compared to a 2nd hand unit, its a big difference.
Old 03-12-2008, 09:47 AM   #13
blueoval
Critical Thinker
blueoval's Avatar
agree. Thats why Im gonna try second hand first. See what I can find. Failing that, new will it have to be.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 03-12-2008, 10:24 AM   #14
blackers10
blackers10's Avatar
ive been quoted 660 fitted for a standard replacment NEW LSD center from Hart Transmissions up here in Brisbane(at Brendale)
then you just need the gears.apparently aftermarket gears from a diff shop are of a harder metal so as to reduce wear and tear compared to the cast standard units
Old 03-12-2008, 11:16 AM   #15
blueoval
Critical Thinker
blueoval's Avatar
Thanks blackers. Thats interesting to compare.
I reckon weighing up the price differences is a must. Still if you can get a decent 2nd hand unit for cheaper, its worth looking into.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 03-12-2008, 11:37 AM   #16
5.0 ED
5.0 ED's Avatar
Okay well gears $450 new, LSD $600 new.
You should be able to get a good 2nd hand LSD diff for it for $250. I got my whole IRS setup for $450 with 3.45 LSD.
Old 03-12-2008, 11:53 AM   #17
blueoval
Critical Thinker
blueoval's Avatar
Thats quite a considerable saving IF you can find a decent unit in good condition.
Here is a question, will the 3.45 gears from an IRS setup fit into a live axle diff setup?
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 04-12-2008, 01:26 AM   #18
5.0 ED
5.0 ED's Avatar
yes they will the gears are the same, but the LSD is different, but you can put an IRS lsd in a live axle, but not visa versa although some people have, in the IRS setup their is a circlip groove thats not in the normal setup.
Old 04-12-2008, 10:07 AM   #19
blueoval
Critical Thinker
blueoval's Avatar
appreciate your knowledge on this. Very helpful. ;)
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 04-12-2008, 12:13 PM   #20
F6 R-Spec
formerly PURSUIT-250
F6 R-Spec's Avatar
It will work using early cones (solid axle ones) in an irs, as they are a 2 piece cone and side gear.
The circlip will locate in the grove.
Hey blueoval your noise will be most likley be coming from small pinion bearing as there the first to chew out.
Cheers Mick.
F6 R-Spec is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2008, 12:23 PM   #21
blueoval
Critical Thinker
blueoval's Avatar
Thanks Mick. Will replacing the diff gears and installing an LSD centre sort the noise out or is that a different area of the diff again that I will need to address?
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 04-12-2008, 01:59 PM   #22
F6 R-Spec
F6 R-Spec's Avatar
Just change all the bearings x2 pinion, x2 carier, x2 axle's.
That will fix the whien. (spelling)
But as mentioned by others your better of with a good 2nd hand 3.45 ratio LSD. More fun. :
Good Luck.
Cheers Mick.
Old 04-12-2008, 02:07 PM   #23
blueoval
Critical Thinker
blueoval's Avatar
Good Luck.
Cheers Mick.
LOL. thanks mate, will do.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 04-12-2008, 11:46 PM   #24
5.0 ED
5.0 ED's Avatar
Pursuit 250 - Yeah it will work putting the 2 piece cone and spider gear in, but its not exactly correct now is it, not to mention your then forcing a circlip in between both forcing the cone harder against the case, so if we can just force things tighter than why do they bother setting the preload correctly with shims.
Old 05-12-2008, 12:21 AM   #25
F6 R-Spec
F6 R-Spec's Avatar
HAhahahahaha, the factory preaload as we no, is good for a blender.
hence the circlip slightly forcing the cone harder into the hat, when building them i ad 2-3 BTR LE front pump shims in between the side gear and cone wich gives you a nice and TIGHT LSD, a litle to tight at the start but in 3-4 weeks she is sweet as 18 YO. :
Cheers Mick.
Old 05-12-2008, 01:29 AM   #26
blueoval
Critical Thinker
blueoval's Avatar
I have got in contact with a member who works at a wrecker and has a complete xr6 live axle diff with 3.45 ratio and LSD setup, axle to axle for $500 cash.
Is this good?
I can pick it up next week to be fitted.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 05-12-2008, 02:26 AM   #27
5.0 ED
5.0 ED's Avatar
Sounds a tad expensive to me, i would have thought they would be more around $300-$400. But I don't exactly go around pricing them either. Along the same lines if its in excellent low km condition then it would be worth spurting some extra $$$ for.
Old 05-12-2008, 02:30 AM   #28
5.0 ED
5.0 ED's Avatar
PURSUIT - 250 thats funny you say that about factory pre load, cause i have noticed in the AU"s its pretty loose but in earlier diff's it was much tighter.
Old 05-12-2008, 06:58 PM   #29
F6 R-Spec
F6 R-Spec's Avatar
Is this good?
It's not exactley CHEAP but it is about the price you would pay retail, as long as the diff has'nt done 400,000 k's, minimal back lash, not noisy and has NO metal partical's in the oil.
Cheers Mick.
Old 08-12-2008, 10:54 AM   #30
blueoval
Critical Thinker
blueoval's Avatar
thanks fellas. I might take a member from SA to come with me to see what they think. I dont want to be ripped off if this item is a POS.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
