Old 06-01-2009, 12:05 PM   #1
namecrap
Default AU service & dipstick
how much do you guys spend on a DIY auto service...ie filter and fluid?
roughly how much fluid would i need to add? I think they hold 10lts but not all of it comes out when u take the pan off?
also is it possible to fit a dipstick to this box? I figure id need to have the box out of the car at the time, take the pan off and maybe the valve body....anyone done this?
namecrap is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2009, 01:58 PM   #2
rag top
rag top's Avatar
I've had a dipstick installed on an AU when the gearbox was out getting a rebuild. From memory, they drilled into the casing.
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2009, 08:14 PM   #3
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Around $50 should cover new filter and oil
Paid about $18 at Burson's (trade price) for filter, oil is about $25 for 4 litres
Just doing a drop the pan change the filter and refill will get out 4-5 litres
Just have car level and fill until oil comes out fill hole, start engine, make sure gears engage properly, (foot on brakes obviously), then recheck, usually you need to add a little bit more.
Dipstick can be added but needs to be drilled in
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2009, 08:17 PM   #4
b2tf
not here much anymore
b2tf's Avatar
You can buy a trans service kit that has a new pan gasket and all the bits you need apart from the fluid for about $30.
