Old 10-02-2009, 10:51 AM   #1
chevaps
Zetec Screamer....
chevaps's Avatar
Default weird noise while in reverse
The other day i noticed a weird noise coming from under my bonnet while reversing. I can get the car into reverse fine, but as soon as i start to reverse, I get a grinding/humming sound from what appears to be the passenger side of the engine bay. Now the strange thing is that it happens most of the time, but not all of the time. Like yesterday while experimenting a bit in a car park, the first few attempts got the sound, but for the rest of the afternoon and night, i got nothing, no matter how hard i gave the gas.
Experimenting a bit, slowly releasing the clutch (with no gas) and then when fully engaged, i give gas and will not get the sound. However, when giving a bit of gas while releasing the clutch, i will usually get the sound. However, it will last all but a second or two and the car will reverse with only the usual whining sound of a manual gearbox in reverse. Before people jump to the conclusion that its the clutch, driving and taking off in the forward gears is perfectly normal with no grinding/humming.
I dont have the time to get to a workshop until the weekend, so im throwing it out there to see if anyone else has had a similar issue and may know whats up. By the way, the car is 2004 1.8 manual focus (with the ib5)
Regards
Tom
White 2004 Ford Focus
Sparco Gear Knob & Aluminium Pedals, 2 1/4" Mandrel Bent Magnaflow Cat-Back Exhaust with 3" SS tip, Full Ford Body Kit with Zetec R Spoiler, K&N panel filter
chevaps is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2009, 01:27 PM   #2
BlackLS
yum
Just guessing but perhaps its a halfshaft bearing? Or an engine mount.
2005 LS Focus LX
250,000kms.
Old 10-02-2009, 06:01 PM   #3
Tj-zetec
Knows nothing. Apparently
Tj-zetec's Avatar
perhaps check your ball joints and any other parts of the suspension and steering.
If something's loose it may be moving into a position when you reverse that creates the noise.
Basically grab the top of one of your front wheels and shake it. If you hear a knocking you've got something loose.
Oh and check your brake calipers too, if they're loose the could be making noises.
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!!
1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here
Tj-zetec is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2009, 05:43 PM   #4
zetec
Zoom Zoom
zetec's Avatar
My advice:
Baked beans will give gas and good sound
Pizza gives me gas but no sound and really stinks
If you want to give gas but not have sound, stick to Pizza.
2012 Mazda3 MPS
Old 12-02-2009, 06:04 PM   #5
Tj-zetec
Tj-zetec's Avatar
Not very helpful.
Amusing, but not very helpful.
(onions do it for me BTW )
Old 12-02-2009, 07:28 PM   #6
More revs
I agree, please don't supply frivolous responses to serious questions.....
Now in my experience those noises are caused by backing into poles.... or other nationalities too slow to get outa the way.
More revs is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2009, 10:56 PM   #7
zetec
Zoom Zoom
zetec's Avatar
Honestly I'm thinking an engine mount might be the culprit, it's possible.
2012 Mazda3 MPS
Old 12-02-2009, 11:29 PM   #8
fordel
Tricolore Tard
Contributing Member
fordel's Avatar
I thought zetec's first answer was spot on.
I think its a great answer.
I think someone is grumpy with you zetec ;)
fordel is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2009, 07:09 PM   #9
zetec
Zoom Zoom
zetec's Avatar
don't hate the playa - hate the game
2012 Mazda3 MPS
Old 14-02-2009, 05:52 PM   #10
Tj-zetec
Tj-zetec's Avatar
I thought an engine mount too.
I really don't believe that it's the gearbox, which i would imagine is a relief to you.
I think you need to run it up on some ramps and go over everything that's a joint, a mount or anything else that will allow movement of the engine and drivetrain.
