Old 13-05-2009, 06:39 PM   #1
EVL BOS
EVL BOS's Avatar
Default AU courtesy lights
hi,
just a quick question, i've got an AU1 nov 98 build XR6 VCT, one of my back courtesy lights is broken and i've got to replace it was wondering if any one knows if there supposed to turn on when the door is opened or the cars unlocked as mine don't.
cheers
EVL BOS is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2009, 10:38 PM   #2
last fairlane
last fairlane's Avatar
Wink Courtesy lights
Hi Ive got an AU Fairmont 1998 and the courtesy lights have a small switch on them which turns them on from the inside or they can be switched the other way and they come on when you open the doors
last fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2009, 11:42 AM   #3
EVL BOS
EVL BOS's Avatar
cool thanks that means there both broken cause there permanently switched the other way and the dont turn on when i open the doors.
Old 14-05-2009, 07:58 PM   #4
WoodysXR6
Wanting a sprint!
WoodysXR6's Avatar
Just pull them out and and have a look at the plastic tab that is in contact with switch, Sometimes they melt from being on for a long period of time.
I just used a soldering iron and remelted the plastic in my old au and it worked fine after that.
Regards, Woody
WoodysXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2009, 10:55 AM   #5
EVL BOS
EVL BOS's Avatar
Regards, Woody
i've looked at them but they look fine i think it's just worn out cause one doesnt work at all while the other turns on when you switch it on.
Old 15-05-2009, 02:30 PM   #6
broken_suave
broken_suave's Avatar
I know mine dont always make a good contact. Sometimes, if you press down on the switch it turns on, but turns off again when you let go. I'll have to give them a clean at some point.
05 BF XR6 ZF 6spd - Stock for now
Previously:
98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project
broken_suave is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2009, 11:19 PM   #7
sikford
THE Fairmont Ghia 75th
sikford's Avatar
it must be an AU thing as mine used to do that but now they seem to work fine
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install.
My Ride
My Build Thread
sikford is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2009, 11:30 AM   #8
AU1114ME
Wish I had tried to solder mine before I bought 2 new ones from ford for $56. After reading this post I went to the shed, found the old ones(I never throw anything away) got out the soldering iron and fixed them both, now got 2 working spare lights.
Thanks Guys
AU1114ME is offline   Reply With Quote Multi-Quote with this Post
